I'm finally starting the Rebel project I bought ...ahem ...much earlier this
year, and I've got a question even before I start. (Hope this isn't an omen.)
As long as I build the top deck portion of the workbench per MAM, am I okay
taking liberties with the uprights and bottom portion? The bottom deck is
just storage and structure for a stable bench, right?
-Ben Ransom, R#534
tail group done, one wing to proseal, the rest for me.
workbench ?
workbench ?
Hi Ben
I can't think of any reason that it would matter.
-Ben Ransom, R#534
workbench ?
Hi Ben
As long as it's stable flat and level itt shouldn't matter. When you build
the fuselage you need to cut a couple holes in the top for the landing gear
brackets to stick through so check to make sure that will work out. You
might want to adjust the height if you're much taller or shorter than average.
omen.)I'm finally starting the Rebel project I bought ...ahem ...much earlier this
Drew DalgleishAs long as I build the top deck portion of the workbench per MAM, am I okay
-Ben Ransom, R#534
workbench ?
Hello?
Make sure the table top is dead accurate level. This is a must for all the
parts, not just the fuse.
Good luck
Murray
bransom@dcsol.com
Sent: Wednesday, December 03, 2003 11:16 PM
Subject: workbench ?
omen.)
-Ben Ransom, R#534
Good luck
Murray
bransom@dcsol.com
omen.)
-Ben Ransom, R#534
