I used a 24 inch long probes with the first 5 inches bendable. Mounted on
the forward top of the root rib and went Diagonal to the outboard low spot of
the tank. This was done to help with the fuel gauges readings ; on the ground
3 point compared to level flight.
Westach will sell direct, ask for there aviation catalog. 707-938-2121
Sonoma CA
Jim R254
Jims170A@cs.com
hi all
can any one who has used westach fuel probes suggest hOw to mount the probes
diagonal across the tank, at root, following main spar ?
mike #007
