engine mount 0-360
Jerry Purdom
engine mount 0-360
Post by Jerry Purdom » Sat Feb 18, 2012 12:04 am
Hi guy's I'm looking for info on 0-360 motor mount. I have talked to Murphy people,eg.Brian, Robin, about the flex in mount about 1/2",two AME I know they beleive that there should be no flex in the mount eg. bottom legs,and rubber mount. Is there any body out there that has some info. I bought FWF kit for Elite for my Rebel. THANKS jerry
Al Paxhia
engine mount 0-360
Post by Al Paxhia » Sat Feb 18, 2012 12:04 am
I don't know how your detecting the flex in your motor mount. If your seeing
movement at the spinner or you can notice vibration when running the engine.
I would be suspect of the prop being out of balance. Unless you have a
friend with a dynamic balance setup go see your local prop shop. If the prop
was not dynamic balanced, you will be happy with the result.
Al
Moose, N526AP
Cc: "jerry purdom" <jerrygoneflying@shaw.ca>
Sent: Wednesday, November 26, 2003 6:08 PM
Subject: engine mount 0-360
Jerry Purdom
engine mount 0-360
Hi Al: I can see the flex when one person pushes up and down on spinner and
then you can see bottom legs of mount flex and rubber mounts move. I have
torque motor mount bolts down, Wayne says his mount flexes and that it
should move,the prop seems to be fine,its a Warp drive 4-blade climb (square
tip) prop.THANKS jerry
Sent: Wednesday, November 26, 2003 7:57 PM
Subject: Re: engine mount 0-360
seeing
engine.
prop
Al
Moose, N526AP
