Cruise Speed - Rebel
Post by Walter Klatt » Sat Feb 18, 2012 12:00 am
Hey, Wayne, at least we got you up again. I know you don't care
about speed, and agree that's not why we built these Rebels. You
posted some good data, though, for those RPM's and speeds.
However, you didn't post your 2675 speed and just wondering what
that worked out to. Just curious, and not trying to force you to
go up again just for that if you don't have it. ;>)
Sent: Wednesday, November 12, 2003 2:19 PM
Subject: Re: Cruise Speed - Rebel
I never cared how fast my airplane went and now
someone wants to know how
much fuel I burnt!!!!!!! You guys are getting toooooo
complicated for me!
:O)))
Probably about 8USgph Dave!! I'll dip the tanks
tomorrow and see what I
burned. I think I can remember where they were before
I took off.
My prop is at 11.5* (with the protactor flush with the
tip end). I used to
run my 100hp x O-235C with the same prop set at 9.5*
Sent: Wednesday, November 12, 2003 4:34 PM
Nice report, Wayne..thanks. Any idea what the fuel
burn was at any of the
particular settings?
I also run a 70" Warp on my tired old 0-235C and
have it set at 9 deg or
so. Cruise is about
90 mph consuming 20 l per hour or about 5.5 gal U.S
. What pitch was used
in these tests?
Dave Stroud, Ottawa, Canada
Christavia Mk 1 C-FDWS
Fairchild 51, early construction
Sent: Wednesday, November 12, 2003 4:44 PM
Subject: Cruise Speed - Rebel
Gave myself a slap today and went flying for 45
minutes before the storm
hit. With all this talk about how fast everyone's
Rebels go I thought
I'd
see what mine really does, for the first time in 8
years! Never really
cared
....as never been in much of a hurry to get
anywhere (except like I said
other day when being chased by a front!).
Mine has Lycoming O-320-C2A x 150 HP - Warp Drive
3 Blade 70" propellor,
6.00 x 6 tires, Wheel pants >OFF<, gear legs
faired (but dirty trailing
edge
of the round tube), 12" compression spring struts
unfaired, normal cub
style
cowl bowl. With full throttle pushed in I can
obtain 2675RPM in level
flight
and no more! Note that with the prop at this pitch
I got off the ground
today, into a 5kt breeze, from a muddy wet strip
in 325 feet using 14*
flaperon!!
I flew N/S/W/E on GPS and added the sum and
divided by 4. All done at
2200ASL Aircraft total weight approximately 1340 lbs
2450RPM with 0 flap/reflex yielded 96.5Knots (111Mph)
2550RPM with 0 flap/reflex yielded 100.25Knots (115Mph)
2550RPM with 6* reflex position yielded
100.75Knots (116Mph)
2550RPM with 12* reflex position yielded 103.5
Knots (119Mph)
Archives located at
https://rebel:builder@www.dcsol.com/default.htm
Archives located at
Archives located at
Bill Delcambre
Post by Bill Delcambre » Sat Feb 18, 2012 12:00 am
Wish I lived closer. I don't believe it. You'd have to show me. :)
Bill
Sent: Wednesday, November 12, 2003 3:44 PM
Gave myself a slap today and went flying for 45 minutes before the storm
hit. With all this talk about how fast everyone's Rebels go I thought I'd
see what mine really does, for the first time in 8 years! Never really
cared
....as never been in much of a hurry to get anywhere (except like I said
Mine has Lycoming O-320-C2A x 150 HP - Warp Drive 3 Blade 70" propellor,
6.00 x 6 tires, Wheel pants >OFF<, gear legs faired (but dirty trailing
edge
of the round tube), 12" compression spring struts unfaired, normal cub
style
cowl bowl. With full throttle pushed in I can obtain 2675RPM in level
flight
and no more! Note that with the prop at this pitch I got off the ground
today, into a 5kt breeze, from a muddy wet strip in 325 feet using 14* of
flaperon!!
I flew N/S/W/E on GPS and added the sum and divided by 4. All done at
2550RPM with 6* reflex position yielded 100.75Knots (116Mph)
2550RPM with 12* reflex position yielded 103.5 Knots (119Mph)
Bill Delcambre
Sounds like you were just looking for a reason to burn up some dead
dinosaurs and you found one. So, yeah, I'm just looking for a ride.
Bill
Sent: Wednesday, November 12, 2003 4:00 PM
That I gave myself a slap!! OR my planes that slow, OR that I can get off
the ground that quick?
.........or you just want a ride don't you Bill !! :o) Wayne
From: "Bill Delcambre" <bdelcambre@cox-internet.com>
Sent: Wednesday, November 12, 2003 4:55 PM
Bill
storm
I'd
cared
said
propellor,
trailing
edge
style
flight
ground
flaperon!!
David Stroud
Post by David Stroud » Sat Feb 18, 2012 12:00 am
Nice report, Wayne..thanks. Any idea what the fuel burn was at any of the particular settings?
I also run a 70" Warp on my tired old 0-235C and have it set at 9 deg or so. Cruise is about
90 mph consuming 20 l per hour or about 5.5 gal U.S . What pitch was used in these tests?
see what mine really does, for the first time in 8 years! Never really cared
....as never been in much of a hurry to get anywhere (except like I said the
6.00 x 6 tires, Wheel pants >OFF<, gear legs faired (but dirty trailing edge
of the round tube), 12" compression spring struts unfaired, normal cub style
cowl bowl. With full throttle pushed in I can obtain 2675RPM in level flight
flaperon!!
Post by Wayne G. O'Shea » Sat Feb 18, 2012 12:00 am
flaperon!!
Bill
I'd
cared
edge
style
flight
flaperon!!
Hadn't been flying for a month and that flight was a big 2 minutes each way
to my neighbours strip, so thought it was about time I burnt some fuel (and
remind myself why I'm in this "racket")! Wayne
Sent: Wednesday, November 12, 2003 5:08 PM
Bill
off
Bill
storm
thought
I'd
really
cared
said
propellor,
trailing
edge
cub
style
level
flight
ground
14*
at
I never cared how fast my airplane went and now someone wants to know how
much fuel I burnt!!!!!!! You guys are getting toooooo complicated for me!
:O)))
Probably about 8USgph Dave!! I'll dip the tanks tomorrow and see what I
burned. I think I can remember where they were before I took off.
My prop is at 11.5* (with the protactor flush with the tip end). I used to
so. Cruise is about
in these tests?
I'd
cared
edge
style
flight
flaperon!!
Well it raining right now at about 22mm/hr according to the sound on the
metal roof and the weather radar (and besides it pitch dark at this end of
the country) and calling for gusting 60K tomorrow and 15cm of snow, so as
much as I'd like to it ain't going to happen this week! I did take a peak
while wound out to 2675 with the flaperons still in full reflex and at the
most I think I picked up 2 knots.
Sent: Wednesday, November 12, 2003 6:00 PM
Subject: RE: Cruise Speed - Rebel
complicated for me!
:O)))
I took off.
tip end). I used to
so. Cruise is about
in these tests?
Rebels go I thought
I'd
years! Never really
cared
edge
style
flight
Knots (119Mph)
Archives located at
Archives located at
