SR/Moose Service bulletin 9 rivets.
Scott & Leere' Aldrich
Post by Scott & Leere' Aldrich » Fri Feb 17, 2012 11:58 pm
From Brian and MAM:
Sent: Monday, November 03, 2003 9:24 AM
To: Scott & Leere' Aldrich
Subject: Re: SR/Moose Service bulletin 9 rivets.
Hi Scott,
If you read it together with para 25, you will see that the nine rivet
pattern is required at the center AND where the bulkhead overlaps the
upright. It is this latter joint where we found the rivets missing.
Regards
Brian Godden
Murphy Aircraft Mfg. Ltd.
bgodden@murphyair.com
From: "Scott & Leere' Aldrich" <flynski@mwutah.com>
To: "Murphy Technical Department" <murtech@murphyair.com>
Sent: Monday, November 03, 2003 4:57 AM
Subject: SR/Moose Service bulletin 9 rivets.
