Moose/SR Quick Build Service Bulletin
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:58 pm
Service Bulletin just posted on MAM site..... for Quick Build factory
failing to install 9 rivets at top of rear door posts and to check yours are
done correctly.
Direct link http://www.murphyair.com/SUPPORT/Bullet ... attern.pdf
Scott & Leere' Aldrich
Post by Scott & Leere' Aldrich » Fri Feb 17, 2012 11:58 pm
Anyone figure this one out yet? The bulletin talks about the joint between
roof bulkhead and upright but the paragraph referenced in the manual is
about the 9 rivet pattern on the center joint in the middle. No need to
remove anything to see these?? Not sure what they are talking about if it is
not these center overlaps.
Scott
Sent: Friday, October 31, 2003 5:45 PM
Subject: Moose/SR Quick Build Service Bulletin
done correctly.
