or thinking about building
I also think it is a good idea (for Murphy} that Van's does not do high
wings (yet)
My Thoughts
Keith Oliver
kboliver@adelphia.net
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Sent: Friday, October 10, 2003 11:01 AM
Subject: Re: Flaperon Control Roof Hanger on Rebe/CD pictures l
Walter,
I was staying quiet so you could get other input, as I'm sure others have
some better ways. Meant absolutely no insult to Sean, but just couldn't let
"as per the manual" be input on this critical area.
The other thing that I have to advise people on is that you can't go by the
pictures supplied on MAM's CD's.
USE THEM A REFERENCE AND IF THEY DON'T MATCH THE INSTRUCTIONS IGNORE THEM.
Especially the float one where the manual tells you one thing and then all
the pictures are of Julius's floats going together in his shop, that have
VERY few factory supplied parts left in them making the pictures VERY
confusing for someone that is just trying to put together what MAM sent them
in the crate.
Sent: Friday, October 10, 2003 9:59 AM
Subject: RE: Flaperon Control Roof Hanger on Rebel
*-------------------------------------------------------------------------*Yes, Wayne, I was expecting to hear from you on this
one, because I do remember the past discussions.
However, as mentioned there appears to be a few
different ways to beef up the area. Then what confuses
things further is to find the Elite controls manual on
the website still uses the original Rebel method with
the single channel and roof bracket.
So, if I'm going to do a fix, I'm just trying to find
out the best recommended method, manuals aside.
Thanks everyone for their input.
https://rebel:builder@www.dcsol.com/default.htm-----Original Message-----
Sent: Friday, October 10, 2003 6:15 AM
Subject: Re: Flaperon Control Roof Hanger on Rebel
I've been staying quiet on this thread, as
we've been here before, but sorry
Sean the single ST-31 (.020) channel and
.032 bracket to the roof does not
"work just fine" for the torque tube hanger
bracket. You haven't looked too
hard....... if you haven't seen this area to
be a problem. I have fixed at
least 7 (possibly more) of these hanger
brackets, that buckle from leaving
aileron/flaperons without gust locks or even
just having a tail wind rip the
stick out of our hands.
At minimum this channel needs to be .032 and
not .020 and it's very easy to
add a layer of material to it by bending up
a channel to fit inside the
existing one if you are already built to
this stage or flying. Better now
than when you go to leave a distant flyin
and find things aren't where they
used to be on the cabin roof!
Wayne O'Shea
Sent: Friday, October 10, 2003 8:17 AM
on the roof don't follow theIf it helps clear up how to put the hangerthese are pic's from thepictures on the CD that Murphy sends as
prototype.very old Elite manual it showsIf anyone has the misfortune of having a
twonew book has the single st31 withfor and aft channels made of st-31. thebulheads and a .032 bracket thatangle clips for and aft to tie it to thefine. The control chapter is onties it to the roof and it works justyou have a problem leave it perMurphy's web site for down load. Unless
thearea that would require a beef upbook I have never seen a problem in thisSean White
Kitplane solutions Inc.
Archives located at
