Amphibiouir float
Dale Kopff
Amphibiouir float
Post by Dale Kopff » Fri Feb 17, 2012 11:54 pm
Since type A transmission fluid is no longer available, what is the
recomended replacement tramsmission fluid used for the amphibious pump?
Dale
N295RT
Amphibiouir float
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:54 pm
Dale, I use Dextron III in everything. Float hydraulics and MAM brake
systems. 10 years and the stuff has never ate an O-ring!!
Sent: Friday, October 03, 2003 5:37 PM
Subject: Amphibiouir float
Dale
N295RT
Legeorgen
Amphibiouir float
Post by Legeorgen » Fri Feb 17, 2012 11:54 pm
Wayne,
Any suggestions on what to use for a hydraulic tank on the Amphibs? MAM has
yet to locate a source for one and I don't think it's on their priority list so
I'm not holding my breath in hopes I'll receive one soon.
Bruce 357R
Amphibiouir float
Something as simple as a quart can from Acetone. Proseal a couple of fuel
tank fittings on the wide side for a couple compression fittings and a clear
tube for sight gauge. Another couple fittings for the inlet and outlet and
don't forget a small vent hole in the original lid.
That's probably 4 tank fittings you don't have though and something you
shouldn't have to do after forking out the $$'s. Get any of your other back
orders yet?
Sent: Friday, October 03, 2003 7:29 PM
Subject: Re: Amphibiouir float
Wayne,
has
list so
Bruce 357R
Legeorgen
Amphibiouir float
I have received most of the back orders for my floats, last I checked. I
called them often and was a squeaky wheel. Other than a few clevis pins and
miscellaneous nuts and bolts hardware that where just missing on the packing list
(you knew about those because you brought them to my attention) which I just
picked up locally because it was more convenient.
I take it MAM have not sent you anything from your back order since May?
Wheels, tubes, tires, tanks, hydraulic switch control and the likes?
Bruce 357R
