engine thrust line
paco
engine thrust line
Post by paco » Fri Feb 17, 2012 11:54 pm
I asked MAM for one when I did my Sub install and they were quick to send me
one. At work now (I would rather be do this than working too!) I can post or
send to you tonight. format is in Autocad.
or got to my picture page, bottom left pic
http://home.cogeco.ca/~farndt/photo.htm
fyi, I installed my engine dead straight with no offset, rudder is in middle
too.
On 10/3/2003 10:08 AM, MJONES@HATCH.CA wrote to MURPHY-REBEL:
-> Received: by dcsol.com (Wildcat! SMTP Router v5.6.450.8)
-> for murphy-rebel@dcsol.com; Fri, 03 Oct 2003 07:21:15 -0800
-> Received: from mail.hatch.ca ([209.226.191.200]) EHLO=hatch.ca
-> by dcsol.com (Wildcat! SMTP v5.6.450.8) with SMTP
-> id 148334156; Fri, 03 Oct 2003 07:21:13 -0800
-> Received: by gateway.hatch.ca id <119119>; Fri, 3 Oct 2003 11:21:08 -0400
-> Message-Id: <03Oct3.112108edt.119119@gateway.hatch.ca>
-> From: "Jones, Michael" <MJones@hatch.ca>
-> To: "Murphy-Rebel (E-mail)" <murphy-rebel@dcsol.com>
-> Subject: engine thrust line
-> Date: Fri, 3 Oct 2003 11:20:10 -0400
-> X-Orig-MIME-Version: 1.0
-> X-Mailer: Internet Mail Service (5.5.2653.19)
-> X-Antivirus-Remover: Message was filtered through wsMailGuard (wsAV)
-> X-Spam-Remover: Message was filtered through wsMailGuard Professional
(wsSG4 using SpamAssassin)
-> hi all
-> since I am shopping around looking at all engine choices I need to find a
-> thrust line drawing for the rebel or dimension, does anyone out there know
-> where it is ??
-> mike#007
-> NOTICE - This message is the property of HATCH. It may also be
-> confidential and/or privileged. If you are not the intended recipient
-> of this message you are hereby notified that you must not disseminate,
-> copy or take any action with respect to it.
-> If you have received this message in error please notify
-> HATCH immediately via mailto:MailAdmin@hatch.ca.
paco
engine thrust line
Posted ACAD drawing and JPG to Rebel/Misc...
This is for the O-235 and I think it shows a few degrees offset?
Hope this helps
On 10/3/2003 3:09 PM, MJONES@HATCH.CA wrote to MURPHY-REBEL:
-> for murphy-rebel@dcsol.com; Fri, 03 Oct 2003 10:18:57 -0800
-> id 158995437; Fri, 03 Oct 2003 10:18:54 -0800
-> Received: by gateway.hatch.ca id <119068>; Fri, 3 Oct 2003 14:18:48 -0400
-> Message-Id: <03Oct3.141848edt.119068@gateway.hatch.ca>
-> To: "'murphy-rebel@dcsol.com'" <murphy-rebel@dcsol.com>
-> Subject: RE: engine thrust line
-> Date: Fri, 3 Oct 2003 14:17:50 -0400
-> please post the autocad dwg, thanx
-> mike#007
-> -----Original Message-----
-> From: paco@dcsol.com [mailto:paco@dcsol.com]
-> Sent: Friday, October 03, 2003 2:14 PM
-> To: murphy-rebel@dcsol.com
-> I asked MAM for one when I did my Sub install and they were quick to send me
-> one. At work now (I would rather be do this than working too!) I can post or
-> send to you tonight. format is in Autocad.
-> or got to my picture page, bottom left pic
-> http://home.cogeco.ca/~farndt/photo.htm
-> fyi, I installed my engine dead straight with no offset, rudder is in middle
-> too.
-> On 10/3/2003 10:08 AM, MJONES@HATCH.CA wrote to MURPHY-REBEL:
-> -> Received: by dcsol.com (Wildcat! SMTP Router v5.6.450.8)
-> -> for murphy-rebel@dcsol.com; Fri, 03 Oct 2003 07:21:15 -0800
-> -> Received: from mail.hatch.ca ([209.226.191.200]) EHLO=hatch.ca
-> -> by dcsol.com (Wildcat! SMTP v5.6.450.8) with SMTP
-> -> id 148334156; Fri, 03 Oct 2003 07:21:13 -0800
-> -> Received: by gateway.hatch.ca id <119119>; Fri, 3 Oct 2003 11:21:08 -0400
-> -> Message-Id: <03Oct3.112108edt.119119@gateway.hatch.ca>
-> -> From: "Jones, Michael" <MJones@hatch.ca>
-> -> To: "Murphy-Rebel (E-mail)" <murphy-rebel@dcsol.com>
-> -> Subject: engine thrust line
-> -> Date: Fri, 3 Oct 2003 11:20:10 -0400
-> -> X-Orig-MIME-Version: 1.0
-> -> X-Mailer: Internet Mail Service (5.5.2653.19)
-> -> X-Orig-Content-Type: text/plain; charset="iso-8859-1"
-> -> X-Antivirus-Remover: Message was filtered through wsMailGuard (wsAV)
-> -> X-Spam-Remover: Message was filtered through wsMailGuard Professional
-> (wsSG4 using SpamAssassin)
-> -> hi all
-> -> since I am shopping around looking at all engine choices I need to find a
-> -> thrust line drawing for the rebel or dimension, does anyone out there
-> know
-> -> where it is ??
-> -> mike#007
-> -> NOTICE - This message is the property of HATCH. It may also be
-> -> confidential and/or privileged. If you are not the intended recipient
-> -> of this message you are hereby notified that you must not disseminate,
-> -> copy or take any action with respect to it.
-> -> If you have received this message in error please notify
-> -> HATCH immediately via mailto:MailAdmin@hatch.ca.
-> To unsubscribe from this list go to:
-> https://www.dcsol.com/public/code/html-subscribe.wcx
-> Archives located at https://rebel:builder@www.dcsol.com/default.htm
-> To contact the list admin, e-mail mike.davis@dcsol.com
John Worden/Nancy Bulman
engine thrust line
Post by John Worden/Nancy Bulman » Fri Feb 17, 2012 11:54 pm
Mike,
I have posted a file which I got from Murphy several years ago.
Look under SR engines - file name is image002.gif.
I forgot to give it a meaningful file name - feel free to correct this.
John
SR012
mike#007
engine thrust line
Mike,
I should have mentioned that the file Murphy sent me is a Word doc
and is 442 KB so I saved it as a WEB page to get the .gif file.
The image resolution in the Word doc is very good but once
saved to the .gif is not so good.
Does anyone know a better way to do this?
I am still on a 56K modem so if you really want the
Word doc I will upload it tonight.
John
Mike,
John
SR012
mike#007
mike.davis
engine thrust line
Post by mike.davis » Fri Feb 17, 2012 11:54 pm
Hi John, just send me the word file directly at mike.davis@dcsol.com and I'll
convert it to a PDF file.
On 10/3/2003 6:08 PM, MURPHY-REBEL@DCSOL.COM wrote to MIKE DAVIS:
Mike,
John
Mike,
John
SR012
mike#007
me
or
Jones, Michael
engine thrust line
Post by Jones, Michael » Fri Feb 17, 2012 11:54 pm
mike#007
too.
-> hi all
know
-> where it is ??
-> mike#007
