Hi All:
My throttle cable did not work as previously planned.The throttle cable with
the rod end bearing didn't work at the angle it was on so I ordered a new
cable from Spruce with a solid wire end friction lock. I put the hole in the
firewall in the centre above where the two hat tracks cross. Haven't got the
throttle hooked up yet but this will work.
Good Luck
Murray
Up & away soon.
