the exhaust. Can you describe it a bit more for me,
please? Do you have any pics or diagrams? Currently, I
have mine supported from the motor mount with a
flexible hanger made from old hose material. It seems
to work OK for the left side, but obviously not for the
right. I did look at mounting it to the engine somehow,
but couldn't come up with a suitable solution.
Angus, sounds like you had the same problem as I have
with that exhaust. Let us know how the new one turns
out.
cribe.wcx-----Original Message-----
yeom
Sent: Friday, July 04, 2003 2:46 PM
Subject: Re: Radio transmition
Hi Walter,
A thought on your exhaust
problems, my old exhaust system
cracked in the same place more than once, it
only came right after I put the
new system in they now use to support the
exhaust ( it all hangs off the
back of the engine ).
Do you have this? Mine is really good now.(
and I didn't have to buy the SS
system)
Alister
Sent: Saturday, July 05, 2003 2:23 AM
Subject: RE: Radio transmition
filter back toYup, tried that, but that's not it.
My first step is to relocate the noisestarted thatthe alternator and see if that helps. Iwill try itlast night and should finish tonight, socouple of tinyagain this weekend. Got a gang of people out at our
cottage again this weekend, so it will be busy.
When I was under the cowl, I noticed agot weldedcracks starting again on my right exhaust pipe near
where the cross-over joins. Same one as II got thelast year near the same spot. So I will have to get
that fixed again before my upcoming trips.to sell manyold, old mild steel exhausts that MAM usedfor the newyears ago. Looks like I may have to springdrop a bit.stainless ones that all you guys now have. With the
rising loonie, I'm hoping the price willshow up a fewWhat next? Why couldn't these problems*--------------------------------------------months ago. Oh well, better now than when I'm 1000
miles from home.
legeorgen@aol.com
Sent: Friday, July 04, 2003 6:58 AM
Walter,
Have you tried another head set? Maybe your
mic is bad
Bruce
http://www.dcsol.com:81/public/code/html-subs
cribe.wcx
Archives located at
-----------------------------*http://www.dcsol.com:81/public/code/html-subsTo unsubscribe from this list go to:
http://rebel:builder@www.dcsol.com:81/default.htmArchives located at
mike.davis@dcsol.comTo contact the list admin, e-mail
Archives located at
