writes:
MIKEWhat about the
exhaust? Build the mount first, then build the exhaust to dodge the mount?
I'd like to use off the shelf headers if possible. If I do, I assume I
should have them mounted before designing the mount, then design the rest of
the exhaust around the mount.
<A HREF="http://www.bgsoflex.com/bestheader.html">Aerodynamic & Rolling Horsepower Computation</A> Try this site for header info.
And IMHO the noise that Chevy's going to make will be MUCH louder than you
think. Even if you just use stainless exhaust tips of the next size up from
you're headers and put in a three ring baffle kit it will take the sharpness out
of it's bark and make it more quiet. With verry little if any back presure.
Phil&Lisa Smith
#460R
N414D
