K + N filter was Re: Float installation - Rebel
Brian Lawson
Post by Brian Lawson » Fri Feb 17, 2012 11:08 pm
Hey Curt,
I don't follow what it is you mention in here:
On Sun, 1 Jun 2003 19:07:13 EDT, you wrote:
One other verification, I am getting a positive 100 rpm more with the
K+N
filter than the stock brackett. No other change!
Challenger aviation in Ohio is stc ing them for a host of aircraft,
including the Cessna that we need for the Rebel. 84.00 US Curt N97MR
Wuzzat??
Take care.
Brian Lawson,
Windsor, Ontario.
wrayt
Post by wrayt » Fri Feb 17, 2012 11:08 pm
You can obtain K&N filters from Performance Improvements here in
Toronto and if they don't have the one you want it normally takes
only a couple of days. They also can get adapters to fit many
different cars ...which one if any would match the Lyc. O-320 i
don't know. I got a adapter for my soob tp match it to the mass
air flow sensor and because this was hanging out on the end of an
elbow I also welded up an additional bracket for support. here's
a summit page that lists a bunch of K&N filters ...mine is like
the very last one. If the following link overflows the line you
may have to put it back together manually to go internetting.
http://store.summitracing.com/product.a ... htype=ecat
Wray Thompson ...Rebel 306 ...home page http://wrayt.tripod.com/
My ICQ number is 29764664
Rebflyer
Post by Rebflyer » Fri Feb 17, 2012 11:08 pm
Well Brian, the K+N filter is a brand name of an air filter. It's been around in automotive circles and other "go fast" type of equipment for quite some time. I used them on my sand rail in the 80's. They allow for better airflow with better cleaning and it's a reusable filter. On the new Corvettes owner web page they speak of dyno tests showing 30+ hp improvement. Thats from the owners not the company.
I must admitt though the brackett p/n that I crossed into the K+N showed that it was from a 152, so maybe I was choking the air flow to begin with.
Enough info? I can't think of anything else. Curt N97MR
Post by Bob Patterson » Fri Feb 17, 2012 11:08 pm
Hi Curt !
Will the K+N pad fit into a Brackett base, or do you have
to change the whole front end ?? Is the K+N filter foam, like
the Brackett ?? Anywhere we can see a photo ????
Cleaner air AND more power - sounds GOOOOOD !!! ;-)
Lots of questions !! :-)
Thanks !
-----------------------------------orig.-------------------------------
capete
Post by capete » Fri Feb 17, 2012 11:08 pm
http://www.knfilters.com/
Sent: Thursday, June 05, 2003 10:06 AM
Subject: Re: K + N filter was Re: Float installation - Rebel
Hi Curt !
Thanks !
quite
showed
Thanks for the address, guys ! Can't find anything LIKE what
I'd need for the Lyc. O-320 - no listing for Brackett, OR Cessna,
or any aircraft .....
Still need help from Curt !!
Hi Curt !
Thanks !
quite
showed
Rebflyer
Hi BOb,
Actually the whole bracket filter box and foam are tossed. The K+N is a pleated type material, and the box and filter are one unit. The company is Challenger aviation out of Ohio and they did have a booth at OSH last year if that's any help for the search. I haven't figured how to do the pic thing yet but I take alot of extra training anyway:):) The actual size is the same as the whole bracket asembly. They are a life time unit. You clean them and reoil them with a lite oil that is easy to come by through any automotive supplier that handles K+N. Easy to find in high performance stuff too. Curt N97MR
Rebflyer
Hi BOb,
Thanks Curt !
Thought I might be able to change before Rambling, but time
is getting short - we leave July 1st ! Guess I'll check them out
at OSH ....
Had K & N's on the previous/previous Rebel, with the 912 -
did replace them after about 8 years. Thought they'd suffered a bit
with all the washings....
Could use another 100 rpm on the Lyc. - and it does seem
to run a bit rich...
At 01:05 PM 6/5/03 -0400, you wrote:
Hi BOb,
N97MR
Legeorgen
Post by Legeorgen » Fri Feb 17, 2012 11:08 pm
Hi Bob,
Your old 912 Rebel probably had a K&N filter on the crabs. That's how every
912 Rotax I've seen are set up.
Bruce
Yep ! Changed them after about 8 years ....
operating costs on 912's sure are high ! ;-) ;-^) :-)
At 06:47 PM 6/5/03 EDT, you wrote:
Hi Bob,
Bruce
