Aileron Mod/Spade weights
Don Boardman
Post by Don Boardman » Fri Feb 17, 2012 11:02 pm
Thanks Wayne, I just found an extra rudder skin that I forgot I had.
The edge is the same fold so will use it for the wider spade.
Just need someone to weigh the new weight for the spade and I'll cast a
new pair.
Warren
I do remember though that the weight, of the weights as supplied by MAM, was
stated many months back by I believe Randy and Don Boardman.
Wayne O'Shea
Hi guys,
Wayne, I went back and found my numbers
When I did my spade upgrades these were the numbers I found.
Original leads 1199.4g & 1201.3g
New leads. 1384.7g & 1363.4g
Regards,
Don B.
Warren Montgomery
Post by Warren Montgomery » Fri Feb 17, 2012 11:08 pm
Thanks Don,
I'll use 1375g as the new target.
Is the shape the same as the original, just wider with less depth from
LE back?
Warren
Hi guys,
Regards,
Don B.
