Coolers
Coolers
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:02 pm
Nope!! I need something to read!!! To darn quiet on here lately!!
Think you'll have a hard time finding an oil cooler unit with inlets and
outlets large enough for your coolant hoses.
Wayne O'Shea
oifa@irishfield.on.ca
Sent: Monday, May 19, 2003 10:32 PM
Subject: Coolers
Anybody tired of hearing from me yet? Well, here's my next question for
learned members of the list. Is there any reason why I couldn't use an
oil
cooler or transmission fluid cooler for engine coolant? The reason I ask
is
that if any of the above could be used it greatly widens my options for
using something off-the-shelf for cooling when I get to that stage.
SR #044
Coolers
Post by Mike Kimball » Fri Feb 17, 2012 11:02 pm
Anybody tired of hearing from me yet? Well, here's my next question for the
learned members of the list. Is there any reason why I couldn't use an oil
cooler or transmission fluid cooler for engine coolant? The reason I ask is
SR #044
LisaFly99
Coolers
Post by LisaFly99 » Fri Feb 17, 2012 11:02 pm
In a message dated 5/19/03 9:05:26 PM Central Daylight Time, mkimball@gci.net
writes:
is
MIKE
A (general rule of thumb) is that you need 1 sq. inch of radiator area for
every cu. inch of engine. NOT always true. You can have a smaller area IF you
have more rows in you're radiator with at least the same amount of volume as
a stock radiator. More is better even if it's just a pint. And GOOD intake
and exit air, that can be tricky sometimes. <A HREF="http://www.indussys.com/customer/motora ... motorad</A> Also check out the link
for a thermostat that's safe to fly with.
<A HREF="http://www.dakotadigital.com/">Dakota Digital Official Homepage</A> Here are some nice instrument options.
Phil&Lisa Smith
#460R
N414D
Coolers
Post by Drew Dalgleish » Fri Feb 17, 2012 11:02 pm
SR #044
Some of the Subaru guys are using automotive air conditioning evaporators.
I think with your big engine you're going to need a lot more cooling than
that. Maybe you should look into what Orenda uses for their engines.
