[203.21.25.174]) by host02.net.voyager.co.nz (8.8.8/8.6.12) with ESMTP id
OAA26173 for <murphy-rebel@dcsol.com>; Thu, 28 Jan 1999 14:59:41 +1300
(NZDT)
Message-Id: <199901280159.OAA26173@host02.net.voyager.co.nz>
Subject: Re: non-symmetrical fuel tanks
Date: Thu, 28 Jan 1999 14:59:19 +1300
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1155
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Hi Bob,
I do notice that my Rebel does definitely alter in aileron trim with
loading, especially with a third seat on one side at the back.
I like your idea of a bungee to take care of the problem, if you wanted to
make it a little more inconspicuous would it be possible to mount the
bungee along the push/pull tube down on the left hand side of the pilots
seat? There could be a slide type of mechanism to lock the bungee in the
desired position that could be easily accessed with the left hand.
What do you think?
Alister
helpFrom: Bob Patterson <bob.patterson@canrem.com>
To: Murphy Rebel <murphy-rebel@dcsol.com>
Subject: Re: non-symetrical fuel tanks
Date: Tuesday, January 26, 1999 5:17 PM
There are several Rebels with smaller tanks on the left - it DOES
aileronswith the balance. Also, you aren't carrying around 50 lb of unneeded
(mostly) fuel ...
I flew a Rebel from BC to Ontario that only had ONE 3 bay tank
on the right - it was ok, but a little awkward taxiing with 2 people &
baggage aboard with the tank full ! (It leaned !!)
No problem in flight, and fine when solo. The weight of the fuel
is not a BIG problem, but it IS more comfortable if you balance a bit.
I usually run the left tank down a bit first, then switch to right,
and back - always keeping more on right until just an emergency bit
left in the left side... It is more comfortable on cruise - the
Afteraren't heavy, but it's surprising how annoying it gets after a couple of
hours holding one wing up - I usually travel XC 'hands-off' !!
The easy solution for this is a small bungee cord attached to
the bottom of the torque tube, and wrapped around the stick. You slide
it up the stick to increase pull to the right, and down for less ...
-----------------------------orig.---------------------------------
At 05:06 PM 1/24/99 -0500, you wrote:Hi
Does anybody have any regrets or opinions on non-symetrical fuel tanks.
the leftmuch thought and waffling I am about to commit to two bays of fuel in
enough fuelwing. I put the normal 3 bays in the right wing. This is more than
littlefor my Subaru Legacy powered Rebel (probably 6 or so gph) but I am a
with theconcerned about the imbalance. Bobp mentioned once that some builders
right. TheRotax engine were going with one bay on the left and two bays on the
from bothimbalance will costantly reduce as fuel is burned (assumining feeding
tanks)...
As always, any comments are appreciated!
Ken R119
