SR 3500 Weight and Balance
Al & Deb Paxhia
Post by Al & Deb Paxhia » Fri Feb 17, 2012 10:59 pm
Phil,
I put the battery, hyd pump, and ELT in the tailcone just aft of the baggage
area. Empty CG on conventional gear was 12.14" and 13.2" on floats. Some
builders are extending the baggage area to offset the firewall forward
weight. I have not run out of elevator authority but still adding aft weight
and testing.
Al, Moose N526AP
---- Original Message -----
Sent: Wednesday, April 30, 2003 3:40 PM
Subject: SR 3500 Weight and Balance
Where is the most common place for the battery in a SR3500 with the IO 540
Lycoming (weight about 454 lb.) Did it go on the firewall or did it need
go into the tail. Your opinion is appreciated. Thanks in advance for
your
time.
Phil McGrogan
Post by Phil McGrogan » Fri Feb 17, 2012 10:59 pm
Lycoming (weight about 454 lb.) Did it go on the firewall or did it need to
go into the tail. Your opinion is appreciated. Thanks in advance for your
time.
capete
Post by capete » Fri Feb 17, 2012 10:59 pm
Put it in the tail as far back as you can.
Peter
SR003
Sent: Wednesday, April 30, 2003 6:40 PM
your
time.
Post by Bob Patterson » Fri Feb 17, 2012 10:59 pm
Hi Phil !
Put it in the back, behind the baggage bulkhead - you'll
want all the weight back there .... Suggest a full toolbox
for the back of the baggage area, too ! ;-) :-)
--------------------------------orig.--------------------------------------
time.
rickhm
Post by rickhm » Fri Feb 17, 2012 10:59 pm
All,
I am thinking tail cone as well. What are people seeing for their battery weight. I was thinking ~30-35 lbs with a larger Odyssey 1200.
Rick Muller
SR70
-------Original Message-------
Sent: 04/30/03 07:13 PM
Subject: Re: SR 3500 Weight and Balance
Phil,
baggage
weight
and testing.
Al, Moose N526AP
540
your
time.
<a target=_blank
href="http://www.dcsol.com:81/public/code/htm ... ibe.wcx</a>
Archives located at <a target=_blank
href="http://rebel:builder@www.dcsol.com:81/d ... ult.htm</a>
<a target=_blank
