Moose firewall
goody
Moose firewall
Post by goody » Fri Feb 17, 2012 10:58 pm
I am starting forward from #2 carrythrough. Planning for the round engine.
Can I continue building the engine mount framework forward to the firewall
as planned or do I need to make any changes to accomodate the round engine?
Jim Goodwin
Don Boardman
Moose firewall
Post by Don Boardman » Fri Feb 17, 2012 10:58 pm
Hi Jim,
Sorry I can't help out. We are building from a quick build.
I guess I would check with MAM.
Don B.
Reply-To: murphy-rebel@dcsol.com
Date: Fri, 25 Apr 2003 21:57:39 -0400
Subject: Moose firewall
Jim Goodwin
goody
Moose firewall
Mr. Boardman,
Thank you for your reply. I decided I'd wait until I receive the mount.
I'd rather build back from the "hard to change part" to what I can change
to accomodate, rather than build forward and then find........ you know....
Jim
Sent: Sunday, April 27, 2003 7:50 PM
Subject: Re: Moose firewall
Hi Jim,
Don B.
engine.
firewall
engine?
Jim Goodwin
Scott & Leere' Aldrich
Moose firewall
Post by Scott & Leere' Aldrich » Fri Feb 17, 2012 10:58 pm
What manual are you using?? 2500 or that plus the 3500 upgrade packet? It
shows any changes. One change I can think of without looking is the side
doubler that goes behind the upper engine mounts is longer and picks up the
vertical door posts now. Some are adding a channel on the firewall behind
the top V brace mount that goes down to at least the horizontal reinforcing
channel.
Scott
Moose #174
goody
Sent: Friday, April 25, 2003 7:58 PM
Jim Goodwin
