what do you use for ventilation?
we are flying in sunny florida, and can't seem
to get enough air!
Shira
Rebel 648R
cabin venting
cabin venting
I use the snap vents on mine, and they provide a lot of
airflow to your face or wherever you want to direct it
on your body, making for very effective cooling during
the hottest days. Before that, I just had the lower
front fuselage vents, and used to sweat my balls off,
even on slightly warm days. The snap vents are not the
most classy solution, but very cheap, simple and
effective.
Archives located at
effective.
cribe.wcx-----Original Message-----
Sent: Monday, April 21, 2003 5:42 PM
Subject: Re: cabin venting
OPEN THE WINDOW SHIRA!! ))
Seriously I have posted pictures to the
archives before of the C3251 snap
vents that when closed are flush with the
window and pop out to scoop the
air, or you can do like I have on my
airplane with a inlet scoop in the wing
root fairing and an adjustable eyeball in
the fuselage wing roots fed with
scat hose between the two.
Sent: Monday, April 21, 2003 7:59 PM
Subject: cabin venting
*--------------------------------------------what do you use for ventilation?
to get enough air!
Shira
Rebel 648R
-----------------------------*http://www.dcsol.com:81/public/code/html-subsTo unsubscribe from this list go to:
http://rebel:builder@www.dcsol.com:81/default.htmArchives located at
mike.davis@dcsol.comTo contact the list admin, e-mail
Archives located at
cabin venting
Seriously I have posted pictures to the archives before of the C3251 snap
vents that when closed are flush with the window and pop out to scoop the
air, or you can do like I have on my airplane with a inlet scoop in the wing
root fairing and an adjustable eyeball in the fuselage wing roots fed with
*-------------------------------------------------------------------------*what do you use for ventilation?
to get enough air!
Shira
Rebel 648R
