Received: from dialup.voyager.co.nz (ts1p07.net.ashburton.voyager.co.nz
[203.21.25.171]) by host02.net.voyager.co.nz (8.8.8/8.6.12) with ESMTP id
TAA16514 for <murphy-rebel@dcsol.com>; Sat, 23 Jan 1999 19:58:36 +1300
(NZDT)
Message-Id: <199901230658.TAA16514@host02.net.voyager.co.nz>
To: "Rebel" <murphy-rebel@dcsol.com>
Subject: Jabaru Engines
Date: Sat, 23 Jan 1999 19:58:10 +1300
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1155
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Hi Folks,
Just went down to the Aero Club bar for a quick one and the right chap was
there, he has used the jabaru engine and has researched them pretty well.
Apparently the earlier ones had no valve lubrication of any significance,
it didn't do them any good! Once they got that solved it was the end of the
problem, they are a very good motor.
They have changed the cylinders now so that the 4 cylinder is producing 80
hp (optional I think), up from the previous 60hp. It weighs 50lb less than
the 912 and costs a bundle of dollars less too (NZ$7000).
What may also be of interest is the new 6 cylinder version produces 120hp.
weighs the same as the 912 and is about the same price, not bad,I would
have thought.
I was warned to beware when comparing the specs of both engines to make
sure the weight of the Rotax includes radiator, coolant, reduction box etc.
Hope this helps.
email: yeoman@voyager.co.nz
Jabaru Engines
Jabaru Engines
Received: from albedo.net (ppp135.albedo.net [206.51.22.154])
by juliet.albedo.net (8.9.0/8.9.0) with ESMTP id JAA32624
for <murphy-rebel@dcsol.com>; Sat, 23 Jan 1999 09:40:03 -0500
Message-ID: <36A9D361.28C4D5EB@albedo.net>
Date: Sat, 23 Jan 1999 08:49:21 -0500
X-Mailer: Mozilla 4.05 [en] (Win95; I)
MIME-Version: 1.0
Subject: Re: Jabaru Engines
References: <199901230658.TAA16514@host02.net.voyager.co.nz>
Jabiru is a very nice and quite complete package. Downside of Jabiru is that
rated power is at a high rpm. Something like 3400rpm I think. Not bad for
fast
cruise but the slower geared prop would be better for takeoff.
MIME-Version: 1.0
fast
etc.Hi Folks,
snip<
have thought.
Hope this helps.
Jabaru Engines
Received: from earthlink.net (ip175a.richmond6.va.pub-ip.psi.net
[38.30.108.175])
by swan.prod.itd.earthlink.net (8.8.7/8.8.5) with ESMTP id RAA29794
for <murphy-rebel@dcsol.com>; Sat, 23 Jan 1999 17:29:10 -0800 (PST)
Message-ID: <36AA7787.BC5DB2D6@earthlink.net>
Date: Sat, 23 Jan 1999 20:29:43 -0500
From: "James A. Remington" <jaremington@earthlink.net>
X-Mailer: Mozilla 4.06 [en] (Win95; U)
MIME-Version: 1.0
These are the same things I heard at Oshkosh. It sounds good to me.
jar
[38.30.108.175])
MIME-Version: 1.0
jar
theHi Folks,
etc.problem, they are a very good motor.
have thought.
Jabaru Engines
Received: from [137.186.227.193] (helo=ms02-193.tor.istar.ca)
for murphy-rebel@dcsol.com
id 104GLc-0007It-00; Sat, 23 Jan 1999 22:36:28 -0500
Mime-Version: 1.0
Message-Id: <E104GLc-0007It-00@mail2.toronto.istar.net>
Date: Sat, 23 Jan 1999 22:36:28 -0500
Thanks for the info, Alister !
Glad to hear Jabiru has solved their problems. If the 6 cylinder
is anywhere near as smooth as our old Continental C-145 was in our
Aeronca Sedan, it should be a real joy to fly behind !!
FWIW - I think 80 hp is about as low as anyone would want to go
for the Rebel, although I have heard of ONE in Czechoslovakia that is
(was ?) flying with a Rotax 532, of 53 hp. !! It apparently flew once
with THREE people aboard !!!
------------------------orig.--------------------------------------
Mime-Version: 1.0
Hi Folks,
have thought.
Hope this helps.
