My understanding is that the SR and the Moose wing attach is the same for
both models. The front spar fitting is bolted solid with shims and the rear
spar attach fitting floats between the fuselage brackets. This is how I did
mine.
Al
Sent: Wednesday, March 19, 2003 10:13 PM
Subject: Fitting the wing
*-------------------------------------------------------------------------*Well, I slid my wing up to the fuselage for the first time and got a
shock. With the front wing fitting hard against the front of the
fuselage fitting there was no way the rear fitting was going to make it.
It looked like the wing fittings were farther apart than the fuselage
fittings. &%#$ how did I screw that up? Taking a look at the problem
it looked like if I moved the front doubler from the inside of the
square tube to the outside like the moose builders have to do it would
give me enough room and it did. But the front wing fitting is hard
against the front of the fuselage fitting to get the rear fitting
pinned. I can't remember the differences between the Moose and Super
Rebel about one fitting "floating" and the other bolted down hard with
spacers or whatever. If I put a spacer on the back of the front wing
fitting to fill the gap with the front wing fitting hard against the
front fuselage fitting and the rear fitting bolted down (won't need any
spacers, it's a good fit) is this acceptable? Any opinions? Thanks in
advance guys.
SR#044
