B&C oil filter adapter
rebel
Post by rebel » Fri Feb 17, 2012 10:52 pm
Ralph,
The 1.4" spacer is also the one to use if using an O-320-E2D dynafocal
mounted Rebel. I posted pictures to the files here about 2 months ago. They
show a 1.4" wooden spacer that I mocked up before returning the 2.5" spacer.
With the 1.4", you will get 1/2- 3/4" clearance from the motor mount and
about 1" in the rear. When installing the 1.4 spacer and oil filter adaptor I
found B&C did not provide enough Locktite 518 in their kit. I had to buy more
but the sealant had partially cured on one of the gaskets when I set it down
on a piece of plastic overnight. B&C sent me a new gasket with assurances
that they would look at providing enough 518 when people order a spacer. The
2.5 spacer is about 1/2 pound heavier than the 1.4.
Good luck, you'll need it
Rick D.
Rebel 404R
-> Date: Sun, 16 Mar 2003 08:11:52 -0500
-> From: Ralph Baker <rebaker@ftc-i.net>
-> Subject: B&C oil filter adapter
-> To: murphy-rebel@dcsol.com
-> Message-id: <000e01c2ebbd$9d2e51c0$a156dad8@oemcomputer>
-> X-Orig-MIME-version: 1.0
-> X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2800.1106
-> X-Mailer: Microsoft Outlook Express 6.00.2800.1106
-> X-Orig-Content-type: multipart/alternative; boundary="----
=_NextPart_000_000B_01C2EB93.B36ED420"
-> X-Priority: 3
-> X-MSMail-priority: Normal
-> Some time ago I posed questions regarding the lack of oil filter
-> clearance when installing an O-360 A4M Lyc using the MAM mount in our
-> Elite. Our final solution was the B & C Specialty Products right angle
-> adapter with 1.4 inch spacer. This provides 1/2 inch clearance to the
-> motor mount and clearance at the rear for a Bosch electric oil temp
-> sender. This unit was chosen to eliminate aditional hose and joint leak
-> potential and to free up firewall space. The workmanship is superb and
-> B & C were excellent to deal with when we had to send a 2 1/2 inch
-> spacer back.
-> Ralph Baker
-> Elite 624E (reserved)
Post by Ralph Baker » Fri Feb 17, 2012 10:52 pm
spacer back.
