Tech Question
moose2b
Tech Question
Post by moose2b » Fri Feb 17, 2012 10:49 pm
-> I was wondering if anyone can direct me to the notice of a modification
-> to the 'V' in the elevator of the SR/Moose.
-> I sent an e-mail to MAM but Brian is away until the 11th of March. We
-> have kit 083 and I understand that the Elevator 'V' has been widened
-> slightly. I am assuming that our skin is an older version so what are
-> the specs for moving the 'V" ribs in order to widen it.
-> Thanks
-> Jim
-> 083SR/Moose
Jim,
My kit (#171) had the narrower 'V', so I'd assume yours does as well. Brian
told me to move the 'V' ribs outboard 3/8ths of an inch on each side. The
other way to make clearance between the elevator and vertical stab rear spar
is to cut back the flange on the VS spar and make up the extra strength by
riveting on reinforcing angle to the back side of the spar. There are pictures
of the interference problem and fixes in the archives under SR tail section.
I found that since I had already drilled the holes for the extra diagonal rib
in the next bay, that the repositioned rib would wouldn't fit at the trailing
edge. There would also be a fit problem with the 1/2 rib closest to the 'V'.
My solution was to widen the 'V' cutout only at the bottom or narrowest part.
Of course, as soon as you start making mods Murphy's Law kicks in (no not
Darryl Murphy!!). The second, opposite direction bend in the 'V' rib weakens
it since I had to cut the flange. That caused me to make up some new top and
bottom gussets that run farther out along the 'V' to reinforce the ribs.
There is a drawing in the archives of this sort of arrangement, which is what
I used as a guide.
Terry Riedel
SR171
moose2b
Tech Question
-> Thanks
-> Jim
-> 083SR/Moose
Jim,
I used as a guide.
Terry Riedel
SR171
Jim Cole
Tech Question
Post by Jim Cole » Fri Feb 17, 2012 10:49 pm
Jim
083SR/Moose
