pull up in the archives. Have never heard of the seat rail measurements as
MAM screwing up, just guys being confused or questioning the fact that the
pilot side rails are 1" further inboard than the passenger side seat. Ie:
they are not semetical. This is to allow the pilot seat to clear the 1" push
pull tube that runs along the pilots door sill area, from the forward
bellcrank to the mixer bellcrank.
Hopefully someone that has the spring gear mounting and layering of panels
freshly in their mind will jump in and help you with your other question.
It's a matter of adding up all the dimensions and making sure that you have
the same thickness at the front and rear bolting area's of the saddles. I
will go through my pictures and see if I can respark my own mind, as I know
the one I did for Mike Fuller didn't really seem to work out right and will
most likely require the front saddle bolt to be shimmed by a small amount.
On Bernie D's rebuild I found that he had the layers in a different order
than spelled out in the manual as well as an extra shim layer on one side
and it worked out perfectly even.
Sent: Friday, February 21, 2003 3:44 PM
JustHello fellow Rebel builders.
Wayne O finally steered me in the right direction to this wealth of info.
whichfound out last night that MAM screwed up on the seat rail measurements
themeans I did too! Channels are already in.
I have a problem with the assembly of the front lower corner wrap(fus452),
withcorner angle (fus 35), SG 13 & 7. This seems like it could end in one big
mess. Does the angle overlap SG 13 & 7, or are SG 13 & 7 trimmed flush
underthe angle? Do you allow enough material of the corner wrap to remain
closethe saddles for an even layering of material? Has anyone noticed how
tothe saddle holes are to the end of the carrythru's? I related what I found
noticedWayne in the message he sent " Many Questions-Few Answers". Has anyone
tube.how far in the 5/16 hole is on the photo for the spring gear mod using the
angle? I estimated that it is about 3/8 of an inch which would made it no
doubtly stronger with more material between the hole and the end of the
seriouslyI haven't drilled out the saddle holes any larger than 3/32 but am
MAMthinking of moving them in a bit further. My measurements are exactly as
*-------------------------------------------------------------------------*has published but I don't like the little edge distance at the end of the
tubes; especially afer reading what trouble has been experienced.
Thnaks in advance
Steve W
