Repairing leaking fuel tanks <after> removing top skin
Post by Wayne G. O'Shea » Fri Feb 17, 2012 10:43 pm
Brian, throw a trouble lamp with a 60 or 100 watt bulb in the tank center
section and loosely set the lid overtop leaving some small openings to let
the air circulate, as at 30F it will take for ever to cure.
After it has cured somewhat, if you are concerned for the last drop of fuel
to drain across, take a drill and add a hole or two through the lower rib
flange just in front of the rear bulkheads. Try not to mess up your new
proseal anywhere though that it might create a leakage channel behind it.
Sent: Friday, January 17, 2003 11:13 AM
Subject: Re: Repairing leaking fuel tanks <after> removing top skin "Safely"
Wayne, a few more questions. I have re-sealed the tank and put a good
amount of pro-seal in the corners between the ribs and bulkheads. When we
first sealed the tank we left small gaps between the ribs and bulkheads
for
fuel to flow. Are these important? Aslo, the temp here gets aroun 30
degrees F at night, should I keep the pro-seal warm to aid in setup?
Thanks, Brian
"Safely"
Date: Sun, 12 Jan 2003 18:24:50 -0500
It's fondue fuel (fuel line antifreeze) and it burns pretty much
invisibly,
so be careful with it as well!! Available at Canadian tire in Gallon
jugs.
Sent: Sunday, January 12, 2003 5:51 PM
"Safely"
I'm curious, what is meth-hydrate? and where do you get it.
Thanks, Brian Amendala
To unsubscribe, send e-mail to list-server@dcsol.com with
UNSUBSCRIBE murphy-rebel in the message body on a line by itself.
STOP MORE SPAM with the new MSN 8 and get 2 months FREE*
http://join.msn.com/?page=features/junkmail
