You're answer is more accurate. I didn't mean to imply the LS6 was physically
bigger, just more power. The LS1 is a 345 hp. And yes, my understanding is
they both about the same size. The LS6 is a few (10-15 lbs heavier). The LS1
runs about $5k without the ECU/accessories and the LS6 runs about $7.5K. I am
planning on the LS1 for 2 reasons, first, I don't see the need for that extra
60 Hp for a SR, and cost. THe 345 is a bit big for a SR as it is.
Rick Muller
SR60
On Sat, 21 Dec 2002 16:25:41 -0900 Mike Kimball <mkimball@gci.net> wrote:
I don't believe the LS6 is physically bigger
than the LS1. I did a lot of
web surfing when I was initially considering
the LS1/LS6 and it appeared
that the extra horsepower was mostly being
obtained from improvements in air
induction through the manifold into the
cylinders. Here's a quote from
Chevy's website:
" The LS6 is, more than anything, robust.
Compared with the LS1, the LS6
aluminum block, cylinder heads, camshaft and
induction systems are revised
for better breathing at high rpm. A positive
crankcase ventilation system
improves oil control during racetrack and
high-lateral-acceleration
maneuvers."
SR#044
[mailto:mike.davis@dcsol.com] On Behalf Of
Rickhm
at home
Sent: Saturday, December 21, 2002 3:24 PM
Subject: RE: Avionics recommendations and stuff
Wayne,
You are correct. There are many similarities
on the surface, but
underneath they are much different. The LS6 is
a bigger engine, 405 HP I
think!
Rick
SR70
[SMTP:oifa@irishfield.on.ca]
Sent: Saturday, December 21, 2002 5:06 PM
Subject: Re: Avionics recommendations and stuff
Brian Robinson is currently working on a FWF
for (Brent?) Davie's Super
Rebel (over London, Ontario way) using I
believe the LS6? Someone correct
me
if I am wrong but I believe this is the newer
"neater" Vettte engine than
the LS1?!.
To:
Sent: Saturday, December 21, 2002 12:56 PM
ecu for export vehicles withRick
I guess you've also considered the stock GMmagazine about a SeaBeeno O2 sensor. There is a write up in Contacthis engine pretty muchwith lots of hours on such a setup. He keptThat gentleman is also in thestock. I can look up his name if you like.that. If memory serves me wellengine conversion business now.
Rickhm at home wrote:While we're talking electronics and all
youV8 I am using is a LS1. It'sare putting a V8 in your SR as am I. The
aevolved engine than the oldbit more expensive, but it is also a more
smalla coil for each cylinder.block V8. The LS1 uses fuel injection andthe small block V8, but thoseThere are hundreds of other changes from
arerequires an electronic moduletwo of the big ones. Subsequently, it
calledtwo companies that I like atthe ECU (Engine control Unit). There are
thehttp://www.haltech.com/Products/ECUs/E11/e11.htmlmoment.
Haltech's E11http://www.electromotive-inc.com/products/tec3.htmlElectromotive Inc's TEC 3.
*-------------------------------------------------------------------------*http://www.dcsol.com:81/public/listserv.htmTo unsubscribe go tohttp://rebel:builder@www.dcsol.com:81/default.htmArchives located atmike.davis@dcsol.comTo contact the list admin, e-mail
Archives located at
*** File "WINMAIL.DAT" has been uudecoded and
attached to this message.
Archives located at
Archives located at
