Rebel TS attach
Rebel TS attach
Post by Wayne G. O'Shea » Fri Feb 17, 2012 10:37 pm
Plan to go out tomorrow and determine my action plan based on all the good
advise received.
Thanks to all.
Ron Hamson
Wayne G. O'Shea wrote:
Thanks Ken! The bulkhead in and out sounds like a good option for Ron as
he
has already drilled out the multi-strap rivets for installation of the
"Ontario" doubler. Since my straps haven't broke and I already have a
doubler, I had planned to leave my straps in. SO Ron fit the new
fittings
and then pull it all out to rivet the FUS84/88 assembly to the Fus-49
bulkhead if you can. Then put it back in. It will go in and out through
larger hole in the Fus-31 as I have done that when building new. I'll
figure
out my own plan of attack, but that sounds like it will work for you
Ron.
As for the throttle cable, I strongly suggest to everyone with a
taildragging aircraft to get rid of the vernier throttle and use stricly
friction lock. I can guarantee when all hell brakes loose that you will
be
unable to push that button and pull to idle fast enough to save
yourself.
TRUST ME I HAVE BEEN ALONG FOR THE RIDE and my ribs still hurt just
thinking
about it!! Either use the supplied vernier control that MAM is/was
suppling
with FWF packages ONLY after grinding the balls out of the control that
allow it to lock and be turned in and out or buy a friction lock control
cable. If you grind the balls out of the vernier one there is still a
friction control ring on it to add enough friction so it will stay where
you
put it.
I will take a couple of the controls I have in the morning Ken and see
how
tight I can radius them without binding in a 180* direction reversal.
Sent: Saturday, December 07, 2002 10:38 PM
Subject: throttle cable
Hi
I don't have a throttle cable to play with but I am wondering if it is
practical to bend one 180 degrees with about a 7"radius (14"diameter).
discounted this idea originally but got to thinking that some
installations probably have two 90 degree bends and this would be
about
the same thing. This is for a Subaru with the butterfly located close
the top center of the firewall which makes routing somewhat
problematic
but straight through the firewall and a 180 back is one possibility.
Since the price is about the same, I was also wondering if a vernier
control is a good idea or if I should stick to a friction lock
control.
thanks and Merry Christmas
PS. Wayne - if you can mount that bulkhead in the tailcone with
clecos,
you could then perhaps remove it through the fuselage to install the
3/16" rivets before any of the other rivets.
