Prop bolt torque?
Prop bolt torque?
Post by Walter Klatt » Fri Feb 17, 2012 10:36 pm
Just wondering what people are using for torque values
on their Sensenich 2 blade metal props with the 3/8
prop bolts. On their web site it recommends 23 - 25
foot pounds. I was using more than that with my Warp
Drive at 30 foot pounds so just wanted to see what
others were doing.
Prop bolt torque?
Post by Wayne G. O'Shea » Fri Feb 17, 2012 10:36 pm
Sounds right, 30's way toooo much on a 3/8 fine thread bolt! Around
210in-lbs is usually spelled out as a maximum on a 3/8 NUT, which is only 18
ft-lbs. The extra 5 to 7ft-lbs they recommend is to make up for the friction
of the bolt shank on the prop holes I would imagine. I use about 25 ft-lbs
on 3/8 bolts and 40 to 42 ft-lbs on 7/16 ones (haven't lost a prop or ever
had a bolt loosen YET!).
Sent: Wednesday, December 04, 2002 10:08 PM
Subject: Prop bolt torque?
others were doing.
Prop bolt torque?
OK, thanks. I remember talking to the Warp Drive guy a
long time ago about that. He wanted the smaller 1/4
inch ones torqued to 120 inch pounds, which too, was a
way more than normal. His reasoning was that the AN
bolts could handle that much, and it was better too
tight than too loose. So that's what I did.
Sent: Wednesday, December 04, 2002 7:32 PM
Subject: Re: Prop bolt torque?
torque values
with my Warp
others were doing.
Archives located at
Archives located at
bransom
Prop bolt torque?
Post by bransom » Fri Feb 17, 2012 10:36 pm
FWIW, I ended up with a cracked Warped drive prop hub on my Kolb, I believe
from going over the recommended torque numbers just a snitch. This can lead to
real trouble and I was lucky to find it. Warp warranty replaced the hub even
tho I told them it was probably my fault. A picture at
http://mae.ucdavis.edu/~ransom/BensAlbu ... ng99a.html if interested.
-Ben 'not quite a Rebel owner' Ransom
On 12/5/02 1:54 PM, WALTER.KLATT@SHAW.CA wrote to MURPHY-REBEL:
-> OK, thanks. I remember talking to the Warp Drive guy a
-> long time ago about that. He wanted the smaller 1/4
-> inch ones torqued to 120 inch pounds, which too, was a
-> way more than normal. His reasoning was that the AN
-> bolts could handle that much, and it was better too
-> tight than too loose. So that's what I did.
-> Walter
-> > -----Original Message-----
-> > From: mike.davis@dcsol.com
-> > [mailto:mike.davis@dcsol.com]On Behalf Of
-> > Wayne G. O'Shea
-> > Sent: Wednesday, December 04, 2002 7:32 PM
-> > To: murphy-rebel@dcsol.com
-> > Subject: Re: Prop bolt torque?
-> > Sounds right, 30's way toooo much on a 3/8
-> > fine thread bolt! Around
-> > 210in-lbs is usually spelled out as a
-> > maximum on a 3/8 NUT, which is only 18
-> > ft-lbs. The extra 5 to 7ft-lbs they
-> > recommend is to make up for the friction
-> > of the bolt shank on the prop holes I would
-> > imagine. I use about 25 ft-lbs
-> > on 3/8 bolts and 40 to 42 ft-lbs on 7/16
-> > ones (haven't lost a prop or ever
-> > had a bolt loosen YET!).
-> > Cheers,
-> > Wayne
-> > ----- Original Message -----
-> > From: "Walter Klatt" <walter.klatt@shaw.ca>
-> > To: <murphy-rebel@dcsol.com>
-> > Sent: Wednesday, December 04, 2002 10:08 PM
-> > Subject: Prop bolt torque?
-> > > Just wondering what people are using for
-> > torque values
-> > > on their Sensenich 2 blade metal props with the 3/8
-> > > prop bolts. On their web site it recommends 23 - 25
-> > > foot pounds. I was using more than that
-> > with my Warp
-> > > Drive at 30 foot pounds so just wanted to see what
-> > > others were doing.
-> > > Walter
-> > > To unsubscribe go to
-> http://www.dcsol.com:81/public/listserv.htm
-> > Archives located at
-> http://rebel:builder@www.dcsol.com:81/default.htm
-> > To contact the list admin, e-mail
-> mike.davis@dcsol.com
-> To unsubscribe go to
-> Archives located at
-> To contact the list admin, e-mail mike.davis@dcsol.com
