Prop bolts/spacer
Prop bolts/spacer
Post by Walter Klatt » Fri Feb 17, 2012 10:34 pm
Thanks, Drew, I'm still looking. I have been trying to
cover all the Canada places first, but no luck so far.
I am also looking at possibly changing my spacer from 2
to 1 1/2 inches (S6). I have some extra clearance with
the new spinner so, that would allow me to use shorter
bolts.
So if anyone has a 1 1/2 inch spacer that they would be
willing to trade for a 2 inch one, please let me know.
Sent: Tuesday, November 26, 2002 4:54 PM
Subject: Re: Prop bolts
At 06:18 PM 11/12/2002 -0800, you wrote:
I managed to get my hands on a really nice freshly
overhauled Sensenich prop for a great price, and am
getting ready to install it. I just
finished doing the
spinner and am now on the hunt for some cheap prop
bolts. Does anyone know if there are any
good used ones
available? I am trying to avoid the
exorbitant price of
a new prop bolt set. I have calculated the
exact length
needed and could go AN if they are available in that
size. In AN terms, I would need an AN6H-64A. In prop
bolt terms, it would be a ...6S9.
My Warp Drive still works fine, so this should be an
interesting comparison on performance. The
Sensenich is
a 74DM6S8-0-54, so am hoping for good float take-off
and climb performance.
Hi walter I checked with my freinds and no
joy on your bolts but this
showed up on the rec.aviation.homebuilt
newsgroup today you might want to
check it out.
"Johnboy" <jondne@knology.net> wrote in message
news:uu5iniag1udid3@corp.supernews.com...
Hi all,
Please reply if you know where I can buy some
real long 3/8" bolts. I need 6 each. The
part number is:
AN6H63A or AN6H63AS
Drop a nickel and call:
Larsen Industries
2758 N. Las Posas Circle
Camarillo, CA 93012
(805) 491-2359
He has a hangar full of bolts.
Rich S.
To unsubscribe go to
http://www.dcsol.com:81/public/listserv.htm
Archives located at
Prop bolts/spacer
Post by Wayne G. O'Shea » Fri Feb 17, 2012 10:34 pm
Walter, if you have a friend with a lathe just chuck it and turn the face
down (after removing the two locator pins)! I had my machinest buddy do a
McCauley 1 1/2" spacer for me and he turned it down to 3/4" thick and ended
up with a truer unit to boot. Had .006 runout when we started and only .002
when we were done.
Sent: Tuesday, November 26, 2002 8:37 PM
Subject: RE: Prop bolts/spacer
bolts.
Prop bolts/spacer
Hmmm, I was wondering, too, if that could be done. I
was not sure if they could be accurate enough in a
machine shop to ensure that my prop will track true.
Also, was not sure if the existing drilled holes would
cause a problem for the lathe.
Thanks, this is one more alternative to pursue.
Sent: Tuesday, November 26, 2002 5:43 PM
Subject: Re: Prop bolts/spacer
when we were done.
been trying to
luck so far.
spacer from 2
clearance with
use shorter
bolts.
they would be
let me know.
Archives located at
Prop bolts/spacer
As long as they dial indicate it first to make sure they have it running
straight when chucked, there should be no problems.
Sent: Tuesday, November 26, 2002 8:52 PM
when we were done.
been trying to
luck so far.
spacer from 2
clearance with
use shorter
bolts.
they would be
let me know.
Archives located at
