George Coy, is there any need for one of these to keep the M462RfFor M14 up
to snuff?? It's a dial indicator that threads into plug hole and it's on
ebay with markings as described below.
Thanks, Wayne
Your looking at a timing indicator(Or TDC indicator) for Russian Radial
engines.Such as M14P,AI14,M14PF,and other simular engines built under
license in China and Poland.This indicator is calibrated to show -8
Timer for Radial
Timer for Radial
The timing device you describe is the Russian version of the old TIME RIGHT
gage we used to use on U.S. Engines. They are useful in finding TDC, but not
so useful for finding the timing point. The crankshaft flanges are marked in
two places with degrees of crankshaft rotation (not prop flange rotation). I
sometimes use this device to determine T.D.C. then by taping a piece of bent
safety wire to the engine at the zero mark use the graduations on the prop
flange.
If you use the device, be cautious as if you move the prop too quickly you
damage the device or the piston. I usually use a thin screw driver or
something like that through the spark plug hole to determine T.D.C. as it is
easier than using the Russian device.
The timing device is part number 10-24-72R. It is part of the tool kits
that we supply. The attached is a description and picture of the tool kit.
George
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Wayne
G. O'Shea
Sent: Tuesday, November 19, 2002 7:12 PM
Subject: Timer for Radial
Thanks, Wayne
flange.
George
G. O'Shea
Thanks, Wayne
Timer for Radial
Thanks George!
Sent: Wednesday, November 20, 2002 8:48 AM
Subject: RE: Timer for Radial
flange.
George
G. O'Shea
Thanks, Wayne
flange.
George
G. O'Shea
Thanks, Wayne
Timer for Radial
George, would the M462 that I have here (that you sold to Rob Helt and I now
own) use the exact same tools as the M14?? If so what is the cost of a tool
kit??
flange.
George
G. O'Shea
Thanks, Wayne
kit??
flange.
George
G. O'Shea
Thanks, Wayne
