Cooling
Cooling
There has been much discussion in the past on this list about 0320 cooling
with the slower amphibs and the fibreglass speed cowl on the Rebel. I did
some work on my exit as per recommendations from this group last Fall, and
thought I had the problem licked. However, now with the hot summer days
(over 30 C a week ago here on the wet coast), I am still not satisfied. I
can't climb at full throttle for more than about 3 minutes before #3 CHT
gets up to 450 and I have to back off and level out for awhile before
resuming climb. Cruise is about 425 on a hot day, and down to about 380 when
it is cool, like a few months ago.
Wayne, I saw on your website a picture of GCYP (Howard's I believe), and it
looked like it had a big shrouded exit on the bottom of the cowl. Do you
have any close-up pictures of that? While I have a big hole and deflector
there for mine, I don't have it extended to the back of the firewall and
don't have lips on it right now either.
Also, I remember you saying that Howard was using a finer pitch Sensenich 2
blader which might have some effect too. I am still running the 3 blade Warp
with the UHS fibreglass spinner. The spinner is slightly smaller than the
cowl, and perhaps this is causing some turbulence at the inlets.
Anyway, I am determined to get this problem licked once and for all now that
summer is here. Any help and ideas from anyone on this would be greatly
appreciated. Thanks.
Cooling
Now if you had of asked that question last night I could have taken my
digital camera (and a tape measure) with me to the Canada Day Celebrations
at Little Lake park and taken some shots of Howard's cowling exit, seeing I
was already wading around in the water for half the day (catching and
launching aircraft around all the swimmers that were trying to beat the
heat).
We will be up to Howard's on Thursday afternoon, for a "USA" Celebration
BBQ, and I will get you some shots then (if I remember). Our current plan
though is to head North from his place, with the motorhome, and we won't be
back until approximately next Wednesday. Mind you I don't have much faith in
that plan going through as that is only if Leah gets a clean bill of health
to travel, after her Dr. visit tomorrow, and I really have my doubts that's
going to happen.
Sent: Monday, July 01, 2002 11:30 PM
Subject: Cooling
heat).
going to happen.
Subject: Cooling
whenThere has been much discussion in the past on this list about 0320 cooling
itit is cool, like a few months ago.
2looked like it had a big shrouded exit on the bottom of the cowl. Do you
Warpblader which might have some effect too. I am still running the 3 blade
thatwith the UHS fibreglass spinner. The spinner is slightly smaller than the
*-------------------------------------------------------------------------*summer is here. Any help and ideas from anyone on this would be greatly
Cooling
Uploaded 4 pictures to Rebel section (or new for now). 2 of the cowling and
2 of the aircraft sitting on Howard's "air lift" to show you what everyone
is building towards in their garages.
The cowling outlet is the original width as supplied by MAM but opened to 4
1/4" before the lip, with the lip dropping another 3/4" to create some draw.
Howard also did "shark" gills below each heat shroud on the HP exhaust
hoping it would draw some heat out of there as well. He also has the air
inlets smoothed out at the top, so the air doesn't turbulate when it comes
in. He told me he was running about 380F cylinders temps in cruise on Canada
Day and it was 35C (45 with Humidex) He says he can still make her hit 500F
in a full power climb out though, if he keeps it up for any length of time!
Howard has an electronic engine monitor that covers all 4 CHT's and 4 EGT's.
The CHT probes are the thread in bayonets in the bottom of each cylinder.
There is also the "easy way" to get air flow out of the cowling, as I did
with Bob P's Rebel, and that is to simply cut out the entire area of the
lower cowling from one side of the exhaust pipe to the other pipe, forward
to just behind the carb heat dump pipe. Bob seems happy with his
temperatures and even complains his oil temp is too low, which is rare on a
Rebel with the speed cowling.
Sent: Monday, July 01, 2002 11:47 PM
Subject: Re: Cooling
INow if you had of asked that question last night I could have taken my
bewas already wading around in the water for half the day (catching and
heat).
inback until approximately next Wednesday. Mind you I don't have much faith
healththat plan going through as that is only if Leah gets a clean bill of
that'sto travel, after her Dr. visit tomorrow, and I really have my doubts
coolinggoing to happen.
Subject: Cooling
didwith the slower amphibs and the fibreglass speed cowl on the Rebel. I
andsome work on my exit as per recommendations from this group last Fall,
Ithought I had the problem licked. However, now with the hot summer days
deflectorwhencan't climb at full throttle for more than about 3 minutes before #3 CHT
resuming climb. Cruise is about 425 on a hot day, and down to about 380itit is cool, like a few months ago.
Wayne, I saw on your website a picture of GCYP (Howard's I believe), andlooked like it had a big shrouded exit on the bottom of the cowl. Do you
Sensenichthere for mine, I don't have it extended to the back of the firewall and
the2Warpblader which might have some effect too. I am still running the 3 bladewith the UHS fibreglass spinner. The spinner is slightly smaller than
*-------------------------------------------------------------------------*thatcowl, and perhaps this is causing some turbulence at the inlets.
Anyway, I am determined to get this problem licked once and for all nowsummer is here. Any help and ideas from anyone on this would be greatly
Cooling
Thanks Wayne, those pictures are most helpful. I just back from a few days
of flying in 30+ heat, and always with a big load, so my engine temps were
near the limits all the time. Also, I badly need those window vents, as
cabin temps were also over limit. Anyway, had a great time on and in the
water, so really shouldn't complain when we get hot weather out here on the
coast.
One thing I noticed from the pictures, is that the bottom of the main
opening comes past the firewall. I think this helps a lot suck out air. I
initially did what you suggested with Bob P's cowl, and had the opening
starting forward from the carb down pipe, and it worked OK on wheels, but
now with floats it was completely unacceptable. I then extended the bottom
opening back a little further and it helped some, but I see from Howard's
that I should extend it even further.
Now I just need some time to do all this. I am back to work next week, and
don't want to be working on my plane on the weekends if flying weather is
good.
Again, thanks, I definitely have some more ideas and work that I can do to
mine now.
Sent: Tuesday, July 09, 2002 2:36 PM
coast.
good.
mine now.
heat).
Subject: Cooling
Cooling
Glad the pics help! Forgot to take a picture of the window vent
installation, but as I said the CC3251's are the way to go as they sit flush
when closed and even if you forget them and swing the window down they push
in on their own.
Will take my camera to our RAA Northern Regional Flyin this weekend and if
Howard comes in I will get you a picture of location/installation.
Available from:
ACS = $7.85/pr
Wicks = $ 8.96/pr
Wagero = $13.65/pr (of course where I just bought 3 sets from, before I
checked pricing elsewhere!!)
Sent: Thursday, July 11, 2002 8:33 PM
Subject: RE: Cooling
in on their own.
Available from:
ACS = $7.85/pr
Wicks = $ 8.96/pr
theThanks Wayne, those pictures are most helpful. I just back from a few days
andcoast.
good.
mine now.
42 of the aircraft sitting on Howard's "air lift" to show you what everyone
draw.1/4" before the lip, with the lip dropping another 3/4" to create some
CanadaHoward also did "shark" gills below each heat shroud on the HP exhaust
500FDay and it was 35C (45 with Humidex) He says he can still make her hit
time!in a full power climb out though, if he keeps it up for any length of
EGT's.Howard has an electronic engine monitor that covers all 4 CHT's and 4
aThe CHT probes are the thread in bayonets in the bottom of each cylinder.
CelebrationsRebel with the speed cowling.
seeingat Little Lake park and taken some shots of Howard's cowling exit,
planIwas already wading around in the water for half the day (catching and
heat).
faithbethough is to head North from his place, with the motorhome, and we won'tback until approximately next Wednesday. Mind you I don't have much
daysinhealththat plan going through as that is only if Leah gets a clean bill ofthat'sto travel, after her Dr. visit tomorrow, and I really have my doubtscoolinggoing to happen.
Subject: Cooling
There has been much discussion in the past on this list about 0320didwith the slower amphibs and the fibreglass speed cowl on the Rebel. Iandsome work on my exit as per recommendations from this group last Fall,thought I had the problem licked. However, now with the hot summer
satisfied.(over 30 C a week ago here on the wet coast), I am still not
CHTIcan't climb at full throttle for more than about 3 minutes before #3
380gets up to 450 and I have to back off and level out for awhile before
andwhenit is cool, like a few months ago.
youitlooked like it had a big shrouded exit on the bottom of the cowl. Do
anddeflectorhave any close-up pictures of that? While I have a big hole andthere for mine, I don't have it extended to the back of the firewall
bladeSensenichdon't have lips on it right now either.
Also, I remember you saying that Howard was using a finer pitch2blader which might have some effect too. I am still running the 3
nowtheWarpwith the UHS fibreglass spinner. The spinner is slightly smaller thancowl, and perhaps this is causing some turbulence at the inlets.
greatlythatsummer is here. Any help and ideas from anyone on this would be
*-------------------------------------------------------------------------*appreciated. Thanks.
Cooling
Since ACS was at Arlington, I just picked up 2 sets. I should have read
Wayne's note more carefully, as I didn't realize you actually got two in a
package, and didn't open it until I got home, so now I have an extra pair.
I see where placement could be very important, though, as I want them so
they will blow on my upper body and face. They don't give you much for
instructions either, so also have to figure out exactly how they are
supposed to work.
Sent: Thursday, July 11, 2002 8:06 PM
in on their own.
Available from:
ACS = $7.85/pr
Wicks = $ 8.96/pr
supposed to work.
in on their own.
Available from:
ACS = $7.85/pr
Wicks = $ 8.96/pr
andcoast.
good.
mine now.
heat).
Subject: Cooling
Cooling
G'day Walter
Would you be interested in selling me your spare set?
Regards
Ian Donaldson
Sent: Sunday, July 14, 2002 1:29 AM
Regards
Ian Donaldson
supposed to work.
Cooling
Hi, Ian. I was going to offer them to one of the local builders here where I
live. I believe you are from down under, so not sure what shipping would be.
Unlike most aircraft parts, these are very inexpensive at 7.85 US from
Aircraft Spruce. I don't know what your local sources are, but you can order
them directly through the web from if you like. Here is the web page:
http://www.aircraftspruce.com/main.html
Go to the Online Catalogue section and use their search for CC3251, and you
can complete the order from there.
Thanks for asking and good luck.
Ian Donaldson
Sent: Sunday, July 14, 2002 5:37 AM
G'day Walter
Regards
Ian Donaldson
Ian Donaldson
G'day Walter
Regards
Ian Donaldson
supposed to work.
Cooling
G'day Walter
Thanks for the info.
Regards
Ian Donaldson
Regards
Ian Donaldson
IHi, Ian. I was going to offer them to one of the local builders here where
be.live. I believe you are from down under, so not sure what shipping would
orderUnlike most aircraft parts, these are very inexpensive at 7.85 US from
Cooling
Dick
Is it a 400 or 360? Murphy's 360 ran real cool. Ron Kakeldey's 400 runs real
hot with the same cowl but we have not flown it since October so will see
what happens after following some of Kevin Kimball's ideas. The acro guys
say the 400's all run hot but they don't seem to care. It may be fine with
US oil in them - if you compare to the P & W 985 it's not so hot.
Steve Rhodes
Moose 173
rhodes5@gci.net
Sent: Monday, March 29, 2004 05:20
Subject: Cooling
Steve Rhodes
Moose 173
rhodes5@gci.net
Subject: Cooling
*-------------------------------------------------------------------------*Moose flyers,
We have our new Moose flying. First flights always bring up interesting
issues-- you will note I said issues, not problems!
We used Murphy's cowling. We are experiencing high CHT. Is anyone out
there who uses the Murphy cowl having the same "issue"? If so, how are
you dealing with it?
Dick and Dave Shotwell
N235DS
Cooling
Moose flyers,
N235DS
N235DS
Cooling
Thanks Kevin. I'll keep you posted.
Dick
Sent: Monday, March 29, 2004 20:53 PM
Dick
hear fromDick,
I have looked at your photos and I tell ya, I cannot see an easy way to
improve the flow in your engine compartment. Keep me posted on what you
*-------------------------------------------------------------------------*others.
Sincerely,
Kevin Kimball, VP Engineering
Jim Kimball Enterprises, Inc.
PO Box 849, 5354 Cemetery Rd.
Zellwood, FL 32798
407-889-3451 phone
407-889-7168 fax
www.jimkimballenterprises.com
www.pittsmodel12.com
Cooling
Hi Steve,
It's a 360. We've only flown it twice for a total of 1.2 hours. We will
fly again soon and develop more data before we get too concerned. But I am
interested in what other Moose flyers are experiencing using the MAM cowl.
Thanks for your input.
Dick Shotwell
N235DS
Moose 096
Sent: Monday, March 29, 2004 21:10 PM
Dick Shotwell
N235DS
Moose 096
realDick
*-------------------------------------------------------------------------*hot with the same cowl but we have not flown it since October so will see
Steve Rhodes
Moose 173
rhodes5@gci.net
Subject: Cooling
Moose flyers,
N235DS
Cooling
Dick,
improve the flow in your engine compartment. Keep me posted on what you hear from
others.
Sincerely,
Zellwood, FL 32798
407-889-3451 phone
407-889-7168 fax
others.
Sincerely,
Zellwood, FL 32798
407-889-3451 phone
407-889-7168 fax
Cooling
Can you post your photos to the list??
Will be starting our cowl install shortly.
Steve H
Moose 213
On 3/30/2004 5:50 AM, DICKS@PMT.ORG wrote to MURPHY-REBEL:
-> Received: by dcsol.com (Wildcat! SMTP Router v5.7.450.9b10)
-> for murphy-rebel@dcsol.com; Mon, 29 Mar 2004 19:40:02 -0900
-> Received: from ([12.42.144.176]) EHLO=mx.pmt.org
-> by dcsol.com (Wildcat! SMTP v5.7.450.9b10) with SMTP
-> id 1742221671; Mon, 29 Mar 2004 19:39:59 -0900
-> Received: from dicks (jadzia-35.twf.pmt.org [216.83.76.193])
-> by mx.pmt.org (Postfix) with SMTP id DB1B3238114
-> for <murphy-rebel@dcsol.com>; Mon, 29 Mar 2004 21:38:17 -0700 (MST)
-> Message-ID: <001001c41611$65ecf660$c14c53d8@dicks>
-> From: "Dick Shotwell" <dicks@pmt.org>
-> References: <12f.3e0d5431.2d9a493c@aol.com>
-> Subject: Re: Cooling
-> Date: Mon, 29 Mar 2004 21:34:46 -0700
-> X-Orig-MIME-Version: 1.0
-> X-Priority: 3
-> X-MSMail-Priority: Normal
-> X-Mailer: Microsoft Outlook Express 6.00.2800.1158
-> X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1165
-> X-Antivirus-Remover: Message was filtered through wsMailGuard (wsAV)
-> Thanks Kevin. I'll keep you posted.
-> Dick
-> From: <KJKimball@aol.com>
-> Sent: Monday, March 29, 2004 20:53 PM
-> > Dick,
-> > I have looked at your photos and I tell ya, I cannot see an easy way to
-> > improve the flow in your engine compartment. Keep me posted on what you
-> hear from
-> > others.
-> > Sincerely,
-> > Kevin Kimball, VP Engineering
-> > Jim Kimball Enterprises, Inc.
-> > PO Box 849, 5354 Cemetery Rd.
-> > Zellwood, FL 32798
-> > 407-889-3451 phone
-> > 407-889-7168 fax
-> > www.jimkimballenterprises.com
-> > www.pittsmodel12.com
-> > https://www.dcsol.com/public/code/html-subscribe.wcx
-> > Archives located at https://www.dcsol.com/default.htm
-> > Archives public username "rebel" password "builder"
Steve H
Moose 213
-> X-Priority: 3
-> Dick
-> > Dick,
-> hear from
-> > others.
-> > Sincerely,
