Acrobat Reader to view SR Gear failure SB
S & L Aldrich
Post by S & L Aldrich » Fri Feb 17, 2012 10:13 pm
Brian, do you have Adobe Acrobat Reader on your computer? It is needed to
view the .PDF files. If not you can download the free reader from this site
http://www.adobe.com/support/downloads/main.html You can select to download
for Windows PC or Macintosh.
If that is not the problem the SB is at the tech support page at Murphy
under Super Rebel. Here is the direct link to the PDF file.
http://www.murphyair.com/SUPPORT/Bullet ... 280502.pdf
The main support page at MAM also has links to the Acrobat Reader Download.
Hope that helps.
Scott
