ATTN: customer service re: SN 179
goody
Post by goody » Fri Feb 17, 2012 10:13 pm
My manual calls for RR-5606 stainless steel rivets to hold the aileron horn to the tube in the wing. My inventory shows no 5606. I do have a batch of 70 labeled and inventoried as RR-5604 but they only measure 1/8 in. dia.x 3/8 in. length. Shouldn't these be 3/16 dia x 1/4 and do I need 5606 for the aileron need?
My manual is written for the 2500. I have the 120 gal fuel option. Am I correct that my fuel bays run out to main rib #8?
Thank you, I am enjoying the build very much so far.
Jim Goodwin
goody@sover.net (goody@sover.net)
802.343.1775
klehman
Post by klehman » Fri Feb 17, 2012 10:13 pm
Hi Jim
I think you might have meant to send this to the factory instead of this
independant builders list. In any event I can tell you that the standard
rebel does indeed require the longer 3/8" grip rivets there. Always a
good idea to measure the part thickness if in doubt. I'm sure MAM will
send the correct rivets if you contact them.
Jim Goodwin
goody@sover.net
802.343.1775
