I'm sure several of you had messages rejected from the list in the last 24
hours... I finished rebuilding the server and moved back over to it
yesterday. The one thing that I did differently is use a fresh installation
of all the software and then try to move only the data and duplicate the
configuration... in the past I've just copied the entire previous
installation over the new installation. I didn't want to do that this time
since this is supposed to be a ground up fresh installation. Anyway, I
missed the list members database... so while the system was up and running
and everything appeared fine... there were no members to any of the lists.
If you posted a message to any of the lists, please just resend it. I have
moved the necessary files onto the server and everyone is once again a
member of the appropriate lists.
Thanks, Mike
