choosing a propellor
Post by Bob Patterson » Fri Feb 17, 2012 10:04 pm
Hi Shira !
You could go for a compromise prop - there are 3 pitches
of Sensenich metal prop recommended for the Rebel.
74" diameter x 54, 56, or 58 inch pitch
The 54 is climb, and the 58 is cruise - I have the 56" on
my O-320. It seems to work well for both - climb is about 1,500 fpm,
with 2 aboard, and cruise is about 125 mph at 2,450 rpm, with faired gear.
I hope to use this prop on amphibs this summer, and don't
expect any problems.
....bobp
---------------------------------orig.----------------------------
At 06:53 PM 4/23/02 -0400, you wrote:
Hello all,
I have a question to all Murphy rebel owners.
I am putting a Lycoming 0-320 on my rebel, and
we haven't decided yet which propellor to go with.
I would like to hear from those of you who have
put on the climb prop or the cruise prop. Those with
the climb prop, what is your rate of climb? and what is
your cruise speed?
Those with the cruise prop, what is your cruising speed?
and what is your rate of climb?
I am trying to decide if it is worth having the climb prop,
because we have 160hp engine. Or is it worth having
more speed when you are in the air.
Thankyou for your responses.
Shira Ellsworth
Murphy rebel #628R
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=windows-1252">
<META content="MSHTML 6.00.2600.0" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT face=Arial size=2>Hello all,</FONT></DIV>
<DIV><FONT face=Arial size=2>I have a question to all Murphy rebel
owners.</FONT></DIV>
<DIV><FONT face=Arial size=2>I am putting a Lycoming 0-320 on my rebel, and
</FONT></DIV>
<DIV><FONT face=Arial size=2>we haven't decided yet which propellor to go
with.</FONT></DIV>
<DIV><FONT face=Arial size=2>I would like to hear from those of you who have
</FONT></DIV>
<DIV><FONT face=Arial size=2>put on the climb prop or the cruise prop.&nbsp;
Those with</FONT></DIV>
<DIV><FONT face=Arial size=2>the climb prop, what is your rate of climb? and
what is </FONT></DIV>
<DIV><FONT face=Arial size=2>your cruise speed?</FONT></DIV>
<DIV><FONT face=Arial size=2>Those with the cruise prop, what is your cruising
speed?</FONT></DIV>
<DIV><FONT face=Arial size=2>and what is your rate of climb?</FONT></DIV>
<DIV><FONT face=Arial size=2>I am trying to decide if it is worth having the
climb prop,</FONT></DIV>
<DIV><FONT face=Arial size=2>because we have 160hp engine.&nbsp; Or is it
worth
having </FONT></DIV>
<DIV><FONT face=Arial size=2>more speed when you are in the air.</FONT></DIV>
<DIV><FONT face=Arial size=2>Thankyou for your responses.</FONT></DIV>
<DIV><FONT face=Arial size=2>Shira Ellsworth</FONT></DIV>
<DIV><FONT face=Arial size=2>Murphy rebel #628R</FONT></DIV>
<BLOCKQUOTE dir=ltr
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px;
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style="FONT: 10pt arial">&nbsp;</DIV></BLOCKQUOTE></BODY></HTML>
Shira Ellsworth
Post by Shira Ellsworth » Fri Feb 17, 2012 10:04 pm
Hello all,
your cruise speed?
Shira Ellsworth
Murphy rebel #628R
Robert Johnson
Post by Robert Johnson » Fri Feb 17, 2012 10:04 pm
Shira, I also have a 160 hp O320 on my Rebel. I am running a Sensenich 74DM-7-0-58 which is a cruise prop. I find my climb with just pilot and 3/4 fuel can reach 2,000 ft per min. on a cool day at 70 mph indicated. With a passenger, this is reduced to a mere 1,500 ft per min. The problems I find with this combination is 1/ If I firewall the throttle in level flight, I can exceed the VNE indicated as the engine approaches the 2700 RPM red line. 2/ For a normal cruise of around 100/110 I have to back off the throttle to 2,000 RPM, and I have had some people tell me this is not good for the engine as it should be running 2200/2300. If I do this I find cruise is to fast for rough air. All I can say at this time is I like the combination ($2800 reasons why) and I would only consider changing if and when I go to floats. Bob- Rebel "652" (ps my empty weight is 978 lbs.)
