Hi everyone!
Ripping apart the "gear box" today for 3500 upgrades and before I drilled
off the door sills and pulled the old Fus-309's out, to replace them with
the Fus-705's, I marked the hole locations to allow getting the bolts in
that hold the Fus-310 saddles in place on the Fus-705's.
I found a really nice way to get the suggested 1" bolt holes in the exact
location required, by bending and slipping a glue gun stick (which is just
under 5/16"!) into the Fus-309(705) bolt hole and then letting it slip back
out. Where she hits on the lower sill wrap is where to drill the pilot hole.
Then open to an inch with a unibit or holes saw and you are ready for bolt
insertion when the time comes.
I also contacted Brian today in regards to front float attachment, before I
close this thing back up. MAM is going ahead with the "prototype" triangle
attach tabs as shown in the 3500 upgrade manual pictures, and seen by anyone
that attended S n F or Osh last year, and they are now available for
purchase. They are referred to as FL-400's and apparently a "kit" is
available with the longer bolts required to install them. Better now while
it's torn apart, than to try and get at those FUS-705 bolts again later. I
already had a parts order in to Elaine, for <another> Rebel rebuild, so
added a set for my Sasquatch to the order.
Regards,
SR3500 - Fus705 to 310 bolts and float attachment
Hi Wayne,
The wrap for the belly (don't have the part # handy) on the 3500 upgrade is
cut in half for installation. I had Murphy roll the part so it fits tight to
the sill. Also when cutting the gear leg slot and FL400's we made three
slots, two for the float attach brackets and one for the gear leg. Murphy
used a large rectangle that when it pulled up around the sill is looks like
it gaps and bends rather sharp. Rolling eliminates the fit problem and the
slots look clean enough that I don't need a cover over the gear leg or the
float brackets.
Al
MOOOOSE#26
Sent: Thursday, February 07, 2002 4:54 PM
Subject: SR3500 - Fus705 to 310 bolts and float attachment
float brackets.
Al
MOOOOSE#26
backHi everyone!
hole.out. Where she hits on the lower sill wrap is where to drill the pilot
IThen open to an inch with a unibit or holes saw and you are ready for bolt
anyoneclose this thing back up. MAM is going ahead with the "prototype" triangle
**that attended S n F or Osh last year, and they are now available for
Regards,
**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself
**** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
**** To contact the list admin, e-mail mike.davis@dcsol.com
This sounds like a good candidate for a photo to be uploaded. I for one
would like to see how/where you cut your slots. I for one think the
prototype looks like it's got a big hole in the side the way it is done now.
195SR
Sent: Thursday, February 07, 2002 7:55 PM
Subject: Re: SR3500 - Fus705 to 310 bolts and float attachment
195SR
isHi Wayne,
tocut in half for installation. I had Murphy roll the part so it fits tight
likethe sill. Also when cutting the gear leg slot and FL400's we made three
drilledit gaps and bends rather sharp. Rolling eliminates the fit problem and the
float brackets.
Al
MOOOOSE#26
Hi everyone!
withoff the door sills and pulled the old Fus-309's out, to replace them
exactthe Fus-705's, I marked the hole locations to allow getting the bolts in
justlocation required, by bending and slipping a glue gun stick (which is
boltbackunder 5/16"!) into the Fus-309(705) bolt hole and then letting it sliphole.out. Where she hits on the lower sill wrap is where to drill the pilotThen open to an inch with a unibit or holes saw and you are ready for
beforeinsertion when the time comes.
triangleIclose this thing back up. MAM is going ahead with the "prototype"
whileanyoneattach tabs as shown in the 3500 upgrade manual pictures, and seen bythat attended S n F or Osh last year, and they are now available for
Iit's torn apart, than to try and get at those FUS-705 bolts again later.
****already had a parts order in to Elaine, for <another> Rebel rebuild, so
Regards,
** To unsubscribe, send e-mail to list-server@dcsol.com with**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself**** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm**** To contact the list admin, e-mail mike.davis@dcsol.com
Thanks Al !! Kind of wondered about the merits of trying to put the supplied
flat .063 in place around a 6 or 7" radius. Something else to be pulling at
the rivets heads as it try's to return to it's flat shape, let alone trying
to pull it around tight to back drill the thing and rivet. I don't have slip
rolls (yet), but the local heating guy does as we had him roll a .040 wrap
for below the cargo door last year. Will see what happens and maybe go over
and get it rolled. I need an igniter for my oil furnace anyway, so I can
remove the one I "McGyver'd" on there last week!
As for the cut out, I looked at that with skepticism when I saw the first
picture of it. Cessna's suck in exhaust when the rubber seal gets rotted
around the gear leg. Can't imagine how much could possible come in through
that large hole, let alone the water when on floats. Had planned to keep the
holes as small as possible and seal around the edges with something
paintable in regards to the float fittings and mfg a rectangular rubber seal
for the gear leg.
Regards,
Sent: Thursday, February 07, 2002 11:55 PM
for the gear leg.
Regards,
isHi Wayne,
float brackets.
Al
MOOOOSE#26
Hi everyone!
Regards,
Mike,
I have uploaded a photo in the SR fuselage section, the only one handy. If
you look close you can see the belly wrap and float brackets.
Al
Sent: Thursday, February 07, 2002 10:39 PM
Al
now.This sounds like a good candidate for a photo to be uploaded. I for one
tightMike
195SR
isHi Wayne,
The wrap for the belly (don't have the part # handy) on the 3500 upgradecut in half for installation. I had Murphy roll the part so it fits
Murphytothe sill. Also when cutting the gear leg slot and FL400's we made three
thelikeused a large rectangle that when it pulled up around the sill is looksit gaps and bends rather sharp. Rolling eliminates the fit problem and
theslots look clean enough that I don't need a cover over the gear leg or
indrilledfloat brackets.
Al
MOOOOSE#26
Hi everyone!
Ripping apart the "gear box" today for 3500 upgrades and before Iwithoff the door sills and pulled the old Fus-309's out, to replace themthe Fus-705's, I marked the hole locations to allow getting the bolts
later.exactthat hold the Fus-310 saddles in place on the Fus-705's.
I found a really nice way to get the suggested 1" bolt holes in thejustlocation required, by bending and slipping a glue gun stick (which isboltbackunder 5/16"!) into the Fus-309(705) bolt hole and then letting it sliphole.out. Where she hits on the lower sill wrap is where to drill the pilotThen open to an inch with a unibit or holes saw and you are ready forbeforeinsertion when the time comes.
I also contacted Brian today in regards to front float attachment,triangleIclose this thing back up. MAM is going ahead with the "prototype"whileanyoneattach tabs as shown in the 3500 upgrade manual pictures, and seen bythat attended S n F or Osh last year, and they are now available for
available with the longer bolts required to install them. Better nowit's torn apart, than to try and get at those FUS-705 bolts again
soIalready had a parts order in to Elaine, for <another> Rebel rebuild,
http://rebel:builder@www.dcsol.com:81/default.htm**added a set for my Sasquatch to the order.
Regards,
** To unsubscribe, send e-mail to list-server@dcsol.com with**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself** Archives located at
********** To contact the list admin, e-mail mike.davis@dcsol.com
