Cleco price alert
Cleco price alert
Post by Wayne G. O'Shea » Fri Feb 17, 2012 9:47 pm
Missed the air tool question! Have never used one, so don't know. When you
start out with the hand pliers make sure you switch hands every 10 clecos or
so, so your muscles grow/ache evenly on each arm!!!!
Sent: Monday, February 04, 2002 1:12 PM
Subject: Cleco price alert
Avery Tools is running a special on Clecos 4 std sizes for
$.32 USD each down from $.38 USD each.
Is this a fair/good/excellent price? Is their quality OK?
Is there a better quality/price source for Clecos?
What air Cleco installation tool do people prefer?
Rob Sexmith
rsexmith@fuse.net
RJ Thomas
Cleco price alert
Post by RJ Thomas » Fri Feb 17, 2012 9:47 pm
Entirely too true!
Cheers, rj
R J Thomas
Lafayette, LA
rj.thomas@halliburton.com
(337) 849-4136
Super Rebel N140SR (still a largish pile of aluminum)
From: Wayne G. O'Shea [mailto:oifa@irishfield.on.ca]
Sent: Monday, February 04,2002 1:25 PM
Subject: Re: Cleco price alert
Rob Sexmith
rsexmith@fuse.net
Rick DeCiero
Cleco price alert
Post by Rick DeCiero » Fri Feb 17, 2012 9:47 pm
Rob,
There is a definite difference in the quality from one cleco vendor to
another. Unknowingly, I had purchased about 100 pieces of poor quality. They
are # 30's. I can not remember where I got them but it was at one of the
standard vendors at Oshkosh. The clecos were new. The thing to look for here is
that the nose of the side pieces are well rounded and tapered in to the center.
Also, make sure that when squeezed, the two side pieces fully collapse to meet.
I now buy these only through the mail and if the parts are not up to my
requirements, they go back. Price is not necessarily the driver for the quality
of these pieces as I have purchased some excellent new clecos for 25 cents
apiece. This was about 6 years ago. I have the air cleco tool from Aircraft
spruce. It was about $75 at the time. This is one tool that you must have
unless you have Popeye forearms.
Good luck you'll need it,
Rick D. (getting closer)
Rebel N754SM
Rob Sexmith
rsexmith@fuse.net
dasstolguy
Cleco price alert
Post by dasstolguy » Fri Feb 17, 2012 9:47 pm
Rob Sexmith
rsexmith@fuse.net
klehman
Cleco price alert
Post by klehman » Fri Feb 17, 2012 9:47 pm
Hi Rob
I got all mine from http://www.aircraft-tool.com/index.html-ssi
Aircraft Tool is usually the cheapest price except they are even cheaper
at Oshkosh or Sun n Fun. They work fine but I have nothing to really
compare them to. I suspect I accumulated about 500 #30 and 400 #40 by
the time I finished the wings. Guys have said I'll use them all again on
the floats. Recommend you get about 10 of the #11 size as well.
Avery also sells a flanging tool that looks like about a 3" round by
half inch thick piece of aluminum with the nylon rollers. You can make
your own but the Avery one is my favourite for putting a small bend or
flange along the edge of the aluminum panels. Not a requirement but it
does keep the edges tight and looks better.
The pneumatic tool sounds silly until you can't sleep due to numb hands
from squeezing clecos by the 100s. I have the one from Spruce but I have
seen it cheaper (US industrial maybe?). Anyway there is a small disk
with an orifice under the hose fitting where it threads into the body of
the tool. I replaced that disk with a smaller orifice so that the tool
hammers less hard when removing an installed cleco. Less air pressure
doesn't help as then it won't squeeze the cleco fully.
Cleco price alert
That's about as good as it gets Rob, but I did recently come across someone
that was claiming $.29 each and will try to figure out who that was again
and post. I am currently working on a deal to buy direct from California
Associated Products (Cleko-Lok brand) in volume. Don't know what the costs
will be and definitely don't wait for me to consummate a deal, as I don't
know if it will ever come for sure!
If you want to get some long grip fasteners, and a few of each side is
always nice/handy (these are the ones with either nuts or wing nuts on them
and grip in usually 1/2" or 1" ranges), go on e-bay and buy them from a guy
by the name of Ray Lawrence his e-bay name is rl100w@aol.com. I just bought
a dozen 3/16 ones for only $10.50US and a dozen 1/8 for only $8.50. These
usually sell for about $4 a piece and it would have been great to have about
60 to 100 (in 3/32, 1/8 and 3/16) of them when doing the SR wings with all
those damn shims under every rib. With the Rebel you will find only a few
places where you need the extra grip that standard cleco's don't offer! Up
until my recent purchase, above, I was making do with 2 x 1/8" ones and 2 x
3/16" ones but it sure would have been nice to have a dozen of each around
before!
Regards,
Rob Sexmith
rsexmith@fuse.net
Cleco price alert
Rick! Who's brand name is stamped onthe side of those low quality cleco's??
Just want to know before I get 10 or 20 THOUSAND from California Associated
and find out they are their Cleko-Lok brand!
Sent: Monday, February 04, 2002 7:21 PM
Rob,
They
here is
center.
meet.
quality
Aircraft
Rebel N754SM
Rob Sexmith
rsexmith@fuse.net
Rick DeCiero
Cleco price alert
Wayne,
I just checked a few and the CLEKOLOK-USA name is stamped on the side of the
poor quality pieces that I have. Maybe this was a bad batch but it doesn't sound
like it. I looked at some stubby ones that don't work too well and the
CLEKOLOK-USA name appears again. I have relegated these to automotive sheet
metal duty as they are terrible to work with not to mention what they do to an
aluminum hole after a few in and outs. I'll probably sell them at an automotive
flea market. Some auto "discounters" sell clecos for $ 1.00 - $1.25 each !!! And
you thought the aviation people were getting hosed?
Most of my clecos are KWIK-LOC USA and they are very nice.
Good luck,
Rick D.
Rob,
They
here is
center.
meet.
quality
Aircraft
Rebel N754SM
Rob Sexmith
rsexmith@fuse.net
Cleco price alert
Thanks Rick!!! I had a look at what I have in the shop today also, and I
have both the Kwik-Loc and the Cleko-lok. The Cleco-lok's I have are 3/32
and they look no different in quality than the kwik-loc ones. If I go ahead
with a deal through the Cleko-lok brand I will ask for a sampling of
everything before the "big" order to be safe that I don't buy junk!
Thanks again.
Sent: Tuesday, February 05, 2002 6:59 PM
Wayne,
of the
sound
sheet
to an
automotive
!!! And
Good luck,
Rick D.
cleco's??
Associated
Rob,
vendor to
quality.
They
for
here is
center.
meet.
my
quality
cents
Aircraft
have
Rebel N754SM
itself
dasstolguy
Cleco price alert
Avery is selling U.S. made Monogram clecos. Any builder experience with
Monogram clecos.
Rob Sexmith
rsexmith@fuse.net
On 2/5/2002 8:56 PM, OIFA@IRISHFIELD.ON.CA wrote to MURPHY-REBEL:
-> Thanks Rick!!! I had a look at what I have in the shop today also, and I
-> have both the Kwik-Loc and the Cleko-lok. The Cleco-lok's I have are 3/32
-> and they look no different in quality than the kwik-loc ones. If I go ahead
-> with a deal through the Cleko-lok brand I will ask for a sampling of
-> everything before the "big" order to be safe that I don't buy junk!
-> Thanks again.
-> Wayne G. O'Shea
-> www.irishfield.on.ca
-> From: "Rick DeCiero" <rsdec1@star.net>
-> Sent: Tuesday, February 05, 2002 6:59 PM
-> Subject: Re: Cleco price alert
-> > Wayne,
-> > I just checked a few and the CLEKOLOK-USA name is stamped on the side
-> of the
-> > poor quality pieces that I have. Maybe this was a bad batch but it doesn't
-> sound
-> > like it. I looked at some stubby ones that don't work too well and the
-> > CLEKOLOK-USA name appears again. I have relegated these to automotive
-> sheet
-> > metal duty as they are terrible to work with not to mention what they do
-> to an
-> > aluminum hole after a few in and outs. I'll probably sell them at an
-> automotive
-> > flea market. Some auto "discounters" sell clecos for $ 1.00 - $1.25 each
-> !!! And
-> > you thought the aviation people were getting hosed?
-> > Most of my clecos are KWIK-LOC USA and they are very nice.
-> > Good luck,
-> > Rick D.
-> > "Wayne G. O'Shea" wrote:
-> > > Rick! Who's brand name is stamped onthe side of those low quality
-> cleco's??
-> > > Just want to know before I get 10 or 20 THOUSAND from California
-> Associated
-> > > and find out they are their Cleko-Lok brand!
-> > > Thanks,
-> > > Wayne G. O'Shea
-> > > www.irishfield.on.ca
-> > > ----- Original Message -----
-> > > From: "Rick DeCiero" <rsdec1@star.net>
-> > > To: <murphy-rebel@dcsol.com>
-> > > Sent: Monday, February 04, 2002 7:21 PM
-> > > Subject: Re: Cleco price alert
-> > > > Rob,
-> > > > There is a definite difference in the quality from one cleco
-> vendor to
-> > > > another. Unknowingly, I had purchased about 100 pieces of poor
-> quality.
-> > > They
-> > > > are # 30's. I can not remember where I got them but it was at one of
-> the
-> > > > standard vendors at Oshkosh. The clecos were new. The thing to look
-> for
-> > > here is
-> > > > that the nose of the side pieces are well rounded and tapered in to
-> the
-> > > center.
-> > > > Also, make sure that when squeezed, the two side pieces fully collapse
-> to
-> > > meet.
-> > > > I now buy these only through the mail and if the parts are not up to
-> my
-> > > > requirements, they go back. Price is not necessarily the driver for
-> the
-> > > quality
-> > > > of these pieces as I have purchased some excellent new clecos for 25
-> cents
-> > > > apiece. This was about 6 years ago. I have the air cleco tool from
-> > > Aircraft
-> > > > spruce. It was about $75 at the time. This is one tool that you must
-> have
-> > > > unless you have Popeye forearms.
-> > > > Good luck you'll need it,
-> > > > Rick D. (getting closer)
-> > > > Rebel N754SM
-> > > > dasstolguy@dcsol.com wrote:
-> > > > > Avery Tools is running a special on Clecos 4 std sizes for
-> > > > > $.32 USD each down from $.38 USD each.
-> > > > > Is this a fair/good/excellent price? Is their quality OK?
-> > > > > Is there a better quality/price source for Clecos?
-> > > > > What air Cleco installation tool do people prefer?
-> > > > > Rob Sexmith
-> > > > > rsexmith@fuse.net
-> > > > > ** To unsubscribe, send e-mail to list-server@dcsol.com with
-> > > > > ** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by
-> itself
-> > > > > ** Archives located at
-> http://rebel:builder@www.dcsol.com:81/default.htm
-> > > > > ** To contact the list admin, e-mail mike.davis@dcsol.com
-> > > > ** To unsubscribe, send e-mail to list-server@dcsol.com with
-> > > > ** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself
-> > > > ** Archives located at
-> > > > ** To contact the list admin, e-mail mike.davis@dcsol.com
-> > > ** To unsubscribe, send e-mail to list-server@dcsol.com with
-> > > ** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself
-> > > ** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
-> > > ** To contact the list admin, e-mail mike.davis@dcsol.com
-> > ** To unsubscribe, send e-mail to list-server@dcsol.com with
-> > ** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself
-> > ** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
-> > ** To contact the list admin, e-mail mike.davis@dcsol.com
RJ Thomas
Cleco price alert
Rob,
I bought all of my clecos from Avery and I have had no significant problems
with them. I have managed to break a few, but I think that has more to do
with heavy handed technique than the quality of the products.
Cheers, rj
R J Thomas
Lafayette, LA
(337) 849-4136
Super Rebel N140SR (Still a large pile of aluminum)
From: dasstolguy@dcsol.com [mailto:dasstolguy@dcsol.com]
Sent: Tuesday, February 05,2002 11:58 PM
Monogram clecos.
Rob Sexmith
rsexmith@fuse.net
ahead
-> Thanks again.
-> Wayne G. O'Shea
-> > Wayne,
side
-> of the
doesn't
-> sound
-> sheet
do
-> to an
-> automotive
each
-> !!! And
-> > Good luck,
-> > Rick D.
-> cleco's??
-> Associated
-> > > Thanks,
-> > > > Rob,
-> vendor to
-> quality.
-> > > They
-> the
-> for
-> > > here is
-> the
-> > > center.
collapse
-> to
-> > > meet.
-> my
-> the
-> > > quality
25
-> cents
-> > > Aircraft
must
-> have
with
-> itself
itself
