Charles O-235 had on it.
As for the O-540 cylinders on an O-320, they are <supposable> giving 170+
horsepower, but I think that was an optimistic sales pitch by the engine
builder, that is no longer in the engine business (sorry B.D. but, have to
be honest here!)! Seems to perform (climb) about the same as my 150 HP
O-320, but it is just a little quicker in Cruise. I figure the engine came
out pretty similar to a high compression O-320 at 160 HP, and no more. Also
a <MUCH> heavier engine with the O-540 cylinders on there, compared to the
original O-320's, so more "teeter totter" work to do!
Regards,
Wayne G.O'Shea
Sent: Monday, December 03, 2001 12:05 AM
Subject: RE: Odyssey Battery
hisI am wondering if standard starters were used or perhaps an aftermarket ??
Also what do O-540 cylinders do for you on an O-320 ??
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
Sent: Sunday, December 02, 2001 11:02 PM
Subject: Re: Odyssey Battery
Bruce, that's what I had put on the firewall for Charles and it cranked
theO-235 over really well. Same 6.5 to 1 compression ratio as your 0-320 will
be, if 150 HP. The Rebel I repaired this spring had an Odyssey battery ( I
think next size up) mounted way down in the tailcone and it cranked over
aO-320 (WITH O-540 cylinders on it!!) "lickidy split"!
Regards,
Sent: Sunday, December 02, 2001 9:56 PM
webSomeone mentioned Odyssey batteries last week, so I looked them up on apage and learned the PC625, recommended battery for a Lycoming 0320, was
is16doAH battery. The battery Gill Cell recomends for this engine is a 25 AH
battery. I like the thought of a 13lb. battery but is it large enough tothe job? Has anyone been using this battery on a Lycoming 0320 and what
******** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself**** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm**** To contact the list admin, e-mail mike.davis@dcsol.com
