The forward pulleys for the elevator are intended to be mounted on the
engine side of the firewall. The other Fairbanks builder and I want to
mount smaller pulleys on the cockpit side of the firewall under the floor
instead. Anybody know if there are any gotchas with this idea.
FYI - Both of us in Fairbanks also plan to mount our flap handle on the
roof. We'll just do lots of weight lifting to be able to pull in flaps.
SR #044
Elevator forward pulleys
Hi Mike, can you clarify your question? I can't see how the elevator pulleys
would ever end up on the engine side of the firewall. Are you running the
elevator cables beneath the floor?
Scott
-> The forward pulleys for the elevator are intended to be mounted on the
-> engine side of the firewall. The other Fairbanks builder and I want to
-> mount smaller pulleys on the cockpit side of the firewall under the floor
-> instead. Anybody know if there are any gotchas with this idea.
-> FYI - Both of us in Fairbanks also plan to mount our flap handle on the
-> roof. We'll just do lots of weight lifting to be able to pull in flaps.
-> Mike Kimball
-> SR #044
Scott
-> Mike Kimball
-> SR #044
Mike probably means the rudder pulleys.
John
John
Scott
-> Mike Kimball
-> SR #044
