Hi everyone,
I'm making great progress on my fuselage. You get a lot done in winter in
Fairbanks, Alaska. Question: How do I paint the bottom of the fuselage
once it is all finished, sitting on it's gear and full of stuff (pulleys,
cables, probably instruments, etc.). One obvious answer is to paint it
before it's on its gear and it can be manhandled by 3 or 4 people onto its
side. But what if I want to wait until the basic airframe is completely
finished? Kinda hard to put it on its side then. Guess I could lay on my
back and paint with the tail raised up somehow.
SR #044
Painting - again
Painting - again
In a message dated 11/7/01 2:13:17 PM Central Standard Time, mkimball@gci.net writes:
Phil&Lisa Smith
#460R
N414D
Thats the way my painter did it.. Guess I could lay on my
Phil&Lisa Smith
#460R
N414D
Painting - again
I sprayed a standard Rebel (primer only so far) by lifting one main
wheel up onto some concrete blocks as far as I dared. Shot half the top
and bottom and then reversed the tilt.
In regards to the featherfill primer filler that Dave recommends for his
fibreglass tips, I have been told that Evercoat has discontinued it in
favour of Slick Sand which seems to be the same thing with (I think)
lower VOC's. This stuff is a two part sprayable polyester primer that
can be built up and sanded. Most places that even know what it is only
sell such a product by the gallon but C-Max in Brampton (Toronto) got a
quart of Slick Sand with a days notice. Seems to work fine although it
doesn't fill pin holes very well. If I hadn't needed some filling for
some fairings I would have just used epoxy primer.
Mike Kimball wrote:
Hi everyone,
Painting - again
Hi Ken
What & where is C-Max? I need to get that done.
Brian #328R
klehman
Sent: Wednesday, November 07, 2001 4:54 PM
Subject: Re: Painting - again
Mike Kimball wrote:
Brian #328R
klehman
Mike Kimball wrote:
** To unsubscribe, send e-mail to list-server@dcsol.com with **Hi everyone,
Painting - again
CMAX Brampton
65 Rutherford Rd.
Brampton
905-451-6646
It is an automotive paint store one block north of an underpass on the
West side of Rutherford.
Slick Sand $28.62 per quart, part #102243 on the invoice. Dale was the
guy I dealt with and he seemed fairly knowledgable. The color (gray)
even matches your tips. It took almost 10 minutes to stir the stuff even
with an electric drill but I thinned it with a little acetone and
sprayed it on with a cheap spray gun.
65 Rutherford Rd.
Brampton
905-451-6646
Hi Ken
Painting - again
Hi Ken
Thanks very much Ken. That is so close to where I work it is ridiculous.
Brian #328R
klehman
Sent: Saturday, November 10, 2001 6:15 PM
CMAX Brampton
65 Rutherford Rd.
Brampton
905-451-6646
Brian #328R
klehman
CMAX Brampton
65 Rutherford Rd.
Brampton
905-451-6646
Hi Ken
