Rebel - ailerons adjustments
G'day Ken and Rick
Thanks for your responses.
I particularly like the thought of making some wedge shaped spacers. That is
a really easy fix, and would solve the problem.
Don't know why I did not think of that!
I had fitted the ailerons before covering and painting, and the fit was OK.
Now the ailerons rub. I really don't want
to cut the rear of the trailing edge. It would spoil my nice paint! But if I
have to I will.
Thanks again
Regards
Ian Donaldson
have to I will.
Thanks again
Regards
Ian Donaldson
Hi Ian !
One thing you can do to avoid wear & tear on the ailerons -
find a gliding club or glider supplier. They have a wide, clear
teflon tape that is used on gliders to allow very tight gaps between
the wing skin & aileron - the tape goes on the aileron and reduces
friction so the skin doesn't dig in ... The added advantage is
much better airflow over the wing.
---------------------------------orig.-----------------------------------
G'day Ken and Rick
have to I will.
Thanks again
Regards
Ian Donaldson
Hi IAN:
I had the same problem. My first wing I built with the old manual, the
spacers weren't as big. I cut 1/8" off the skin,then another 1/8th. Not
wanting to have a rippled edge I lay the skin on the table and clamped a
straight edge on it and sliced it off with a knife. This did a good job.
At the factory (MAM) they said as BOB suggested, put an anti wear pad on the
aileron, This reduces the gap to almost zero keeping smooth air flow.
GOOD LUCK
Murray Cherkas
REBEL 505
GOOD LUCK
Murray Cherkas
REBEL 505
G' day Murray
Thanks for your response. I really don't want to cut the trailing edge as it
is now painted.
What I have done is to make some tapered spacers that have given me the
necessary gap.
I will get some tape asBOBP suggests.
Regards
Ian Donaldson
is now painted.
necessary gap.
Regards
Ian Donaldson
G'day bobp
Thanks for your hints. I have made tapered washers that seem to do the
trick.
I will investigate that glider tape. Seems a good idea to me!
Regards
Ian Donaldson
trick.
Regards
Ian Donaldson
I'm using tape I got at lee valley tools. They call it low friction tape
and sell it for use on tool fences. It's a clear UHMW tape 1" wide and
about 1/16" thick. I only used it over the rivet heads and so far its
working great.
working great.
-----------------------------------------------------G'day bobp
trick.
Regards
Ian Donaldson
G'day Drew
Thanks for your reply.
Down under we don't have any Lee Valley tools.
Just maybe the tape is available locally, and so that I can describe it, I
would like to know just what tool fences are, and what UHMW tape is.
Do you know who manufactures the tape?
Regards
Ian Donaldson
Regards
Ian Donaldson
G'day IanDown under we don't have any Lee Valley tools.
Regards
Ian Donaldson
Lee Valley tools is a canadian company that specializes in high end
woodworking and gardening tools they have a great catalog and if you ever
get into one of their stores you'll have a very hard time leaving.
Tool fences are the guides on table saws and the like that help you cut in
a straight line.
UHMW stands for ultra high molecular weight. I checked the roll and theres
nothing on it saying who the manufacturer is.
I did a quick search on the internet for UHMW and got these sites
G'day
Thanks to those who replied
Now I understand just what UHMW is.
I really must live in a vacuum as I had never heard of it before.
I'm now confident that I can locate some here in Australia.
Thanks again and regards
Ian Donaldson
Ian Donaldson
