unsubscribe
Andreas Blech
unsubscribe
Post by Andreas Blech » Fri Feb 17, 2012 9:17 pm
unsubscribe
unsubscribe
Post by Wayne G. O'Shea » Fri Feb 17, 2012 9:17 pm
Take care Andreas! Hope your crops have been good.
Sent: Tuesday, October 16, 2001 8:26 PM
Subject: unsubscribe
unsubscribe
Rick & Cathy Ford
unsubscribe
Post by Rick & Cathy Ford » Fri Feb 17, 2012 9:21 pm
unsubscribe
DCNIBLETT
unsubscribe
Post by DCNIBLETT » Fri Feb 17, 2012 10:24 pm
Angus McKenzie
unsubscribe
Post by Angus McKenzie » Sat Feb 18, 2012 2:41 pm
Hi All
Just a short note to say I'll be away till late Feb so am unsubscribing till then.
Myself and three fellow Fire-fighters from London are leaving tomorrow for Sudan to work at a mission there building a school...........Angus
Brad Sablosky
unsubscribe
Post by Brad Sablosky » Sat Feb 18, 2012 2:53 pm
please unsubscribe me
unsubscribe
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:53 pm
Follow the links below and do it yourself :O)
To:
<rebel-builders@dcsol.comrebel-builders@dcsol.comrebel-builders@dcsol.com>
Sent: Friday, January 27, 2006 12:36 PM
Bill Wagner
unsubscribe
Post by Bill Wagner » Sun Feb 19, 2012 10:57 am
Please unsubscribe me - I will be away for the next two months.
Bill Wagner
rebel-builders-d digest
Sent: Monday, July 03, 2006 6:00 PM
To: rebel-builders-d@dcsol.com
Subject: [rebel-builders-d] DIGEST - rebel-builders-d
Digest of list: rebel-builders-d Total messages in digest: 2
1 Date : Mon, 03 Jul 2006 00:49:16 +0000
Subject: Re: [rebel-builders] Fuel plumbing for Andair valve
2 Date : Sun, 02 Jul 2006 20:26:37 -0700
---------- Digest Message #1 ----------
Date: Mon, 03 Jul 2006 00:49:16 +0000
To: rebel-builders
Jesse,
I have just finished installing an Andair fuel valve, without extension
shaft, in the floor between the front seats, forward of the flap handle.
I made a support web of 0.040" steel to position the valve just under a
short section of the 9" wide center floor panel. The support web allows
you to get under the valve to wrench on the valve connections. Since the
valve handle and escutcheon plate are mounted at floor level, I've added
a 4x4x2" hinged box over the handle to keep the shoes and coffee out of
the valve area. The box has a plexiglass lid to view the handle/valve
positions. I'll email you a couple of pics if you like.
Jack Joos, SR193
Thanks Ron & Ken,
I have considered the extension, I just wanted to save the extra $100.
and I was hesitant to add more possible failure points to the valve.
It sounds like that might be the best option though if I do end up
using the Andair.
My reasons for wanting to use it are; A) putting the selector in front
of you where it will be in your scan. B) Having a fuel shutoff closer
to the firewall in case of engine fire. C) It looks cool.
Practicality may win out, but I haven't given up yet.
Jesse
Have you considered the extension rods Andair makes for their valve
selector switches? You could place the selector some distance from the
valve. See http://www.andair.co.uk/system/index.html
Ron
254R
Reply-To:
Date: Tue, 27 Jun 2006 22:32:15 -0400
One consideration might be that inpectors could want a water drain in
EVERY low point of the fuel line which you seem aware of. And not
just water from the fuel tank as they may even be concerned about
water separating out of the fuel in the line and freezing during
extended seasonal parking. Seems unlikely to me but I guess it could
cause a partial blockage. Another is that you should avoid any high
points for air or vapour to collect in and restrict liquid flow. An
upslope to the valve and a downslope to the gascolator could be a
problem. Gets more difficult if you are catering to tailwheel and
also floats. And of course every right angle fitting will reduce the
flow a bit.
The simple MAM design has its advantages.
Jesse Jenks wrote:
I am trying to figure out a preliminary plumbing plan for the
between-the-seats area. I want to use an Andair valve. I will have
center
console between the seats to cover the controll cables. At this
point I
see
2 placement options. One would be horizontally mounted on top of
the console. This may be a tight fit with fuel lines and cables in
a 4" wide console. I will also have the hydraulic pump between the
seats aft of the console. Option 2 is to mount the fuel valve
vertically, below the instrument pannel, on a center pannel that
would connect the instrument pannel with the center console. This
would put the valve about 8" off the floor, come to think of it,
either option will raise the valve up from
floor
level. So my question is how is this going to effect fuel and water
flow
in
the lines? I assume with all the head pressure from the wing tanks,
fuel
will not have a problem flowing up hill a bit from the floor before
going forward to the firewall. I will have low point drains between
the tanks
the selector valve, so the vertical section of plumbing shouldn't
be a problem for water draining. Am I right to assume any water
forward of the selector valve will drain forward to the gascolator
and be taken care of there (assuming the line has a down slope as
it goes forward)?
Jesse
List archives located at: https://www.dcsol.com/login username
---------- Digest Message #2 ----------
Date: Sun, 02 Jul 2006 20:26:37 -0700
To: rebel-builders
Jack,
I would love to see some pics. Post them to the archives if you can.
The Rebel floor is only 2" deep. I think the SR has more room under the
floor, but I would like to see your installation anyway. I have sprouted
many ideas already from looking at Moose and SR construction pics.
Thanks.
Jesse
Jesse,
handle. I
short
section of the 9" wide center floor panel. The support web allows you
get under the valve to wrench on the valve connections. Since the valve
handle and escutcheon plate are mounted at floor level, I've added a
4x4x2"
hinged box over the handle to keep the shoes and coffee out of the
valve
area. The box has a plexiglass lid to view the handle/valve positions.
I'll
Jack Joos, SR193
Thanks Ron & Ken,
$100.
and I
was hesitant to add more possible failure points to the valve. It
sounds
like that might be the best option though if I do end up using the
Andair.
front
Jesse
Ron
254R
Reply-To:
in
just
water from the fuel tank as they may even be concerned about water
separating out of the fuel in the line and freezing during extended
seasonal parking. Seems unlikely to me but I guess it could cause a
partial blockage. Another is that you should avoid any high points
for
air or vapour to collect in and restrict liquid flow. An upslope to
valve and a downslope to the gascolator could be a problem. Gets
more
difficult if you are catering to tailwheel and also floats. And of
course every right angle fitting will reduce the flow a bit.
Jesse Jenks wrote:
have a
center
point
see
4"
wide
aft of
instrument
off
from
floor
water
flow
in
tanks,
fuel
before
going
tanks
be
forward of
care
Unsubscribe: rebel-builders-d-unsubscribe@dcsol.com
