Tip's follow up
Murray & Carol
Tip's follow up
Post by Murray & Carol » Fri Feb 17, 2012 9:17 pm
Hello from Calgary:
This is a follow up from my tweeking tip on the cage.
When you get to the part that says cleco Fus 40 to 39 I cut Fus 40 at Fus
2's so that I could cleco Fus 40 in the front row of pre punched holes in
Fus 39. If you pull Fus 40 back to cleco into second row of rivets in Fus 39
it will be to far back. Fus 7 overlaps Fus 40 on Fus 5 carrythrough's. The
holes in Fus 26 should line up with the holes in Fus 40 so as to be riveted
to the flange of the bulkhead. This issue seems a little vague in the
manual. When all is said and done Fus 40 buts into the Fus 5 brackets and at
this point you have to drill a hole in Fus 39 in order to cleco 39 @ 40
together.
Good luck to all
Murray Cherkas
REBEL 505
