SR Fuel Tanks
RJ Thomas
SR Fuel Tanks
Post by RJ Thomas » Fri Feb 17, 2012 9:16 pm
Good morning!
Can anyone confirm that the optimum location of the fuel outlet fitting for
a SuperRebel is 17 inches aft of the main spar? It seems as though I read,
or heard, or perhaps dreamed that the "optimum" location has been changed at
least once.
Cheers, rj
R J Thomas
Lafayette, LA
rj.thomas@halliburton.com
(337) 849-4136
Super Rebel N140SR
toddedgar
SR Fuel Tanks
Post by toddedgar » Fri Feb 17, 2012 9:16 pm
That is what Murphy told me to do back in July.
The reason is that this is to compensate for a
low fuel condition in a descent.
Scott & Leere' Aldrich
SR Fuel Tanks
Post by Scott & Leere' Aldrich » Fri Feb 17, 2012 9:16 pm
Why not two, one fore and one aft? I know of at least one SR this way and I
think I plan on doing the same with a boost pump.
toddedgar@dcsol.com
Sent: Wednesday, August 29, 2001 11:56 AM
Subject: SR Fuel Tanks
murphy-rebel mailing list.
SR Fuel Tanks
Post by Mike Kimball » Fri Feb 17, 2012 9:16 pm
The original location of the fuel outlet was at the rear of the root rib.
MAM moved the location only once that I know of to a point about two thirds
back on the root rib. 17 inches sounds about right, but I don't have the
manual in front of me right now with the change. Apparently, there were
some fuel starvation problems while in a steep descent with low fuel when
the outlets were at the back.
SR#044
RJ Thomas
Sent: Monday, August 27, 2001 4:11 AM
Good morning!
least once.
Cheers, rj
R J Thomas
Lafayette, LA
(337) 849-4136
Super Rebel N140SR
Fred Darnell
SR Fuel Tanks
Post by Fred Darnell » Fri Feb 17, 2012 9:16 pm
I considered one fore and one aft as I was originally planning to copy
Cessna's design that has one fuel line routed forward of each door and one
routed aft of each door, meeting up in the floor on each side. But, if you
plan to have only one line going to two outlets you must do something to
prevent an outlet from being exposed during climb or descent in a low fuel
condition. This will allow air to be drawn into the lines (or so I've been
warned). I decided on the center position after being told by MAM that it
was not acceptable to route a fuel line down the forward posts due to the
size hole required in the forward post channels.
Fred Darnell
SR066
Sent: Wednesday, August 29, 2001 3:13 PM
Subject: RE: SR Fuel Tanks
toddedgar@dcsol.com
cgill
SR Fuel Tanks
Post by cgill » Fri Feb 17, 2012 9:16 pm
RJ,
On our SR we did the Cessna thing and put an
outlet in the front and rear corner of each
tank. One line runs forward (around, not
through, the front post and down along the front
of the post) and the other line runs back and
down to tie together under the floor before going
to a 3 way tank selector under the flap handle.
We installed the lines in this manner at the
suggestion of several A&P's.
After 13 hours of flight this system is still
working. With the plane sitting on its tail
wheel I can draw down to the last 1/2 gallon in
each tank.
Chris Gill
SR N4965, #025
Good morning!
least once.
Cheers, rj
R J Thomas
Lafayette, LA
(337) 849-4136
Super Rebel N140SR
