more engines
Drew and Jan
more engines
Post by Drew and Jan » Fri Feb 17, 2012 8:56 pm
http://www.jabiru.net.au/engines/8cyl.html
Check out this site for a possible elite or really hot rebel engine.
more engines
Post by Bob Patterson » Fri Feb 17, 2012 8:56 pm
Hmmmmmm....... might be a BIT long, at almost 1 meter !
Not sure about the size of those horses, either ... but it's
nice to see someone developing new choices. Even if it turns out to
be 130 hp, it's worth a look, if the price is right.
.......bobp
--------------------------------orig.--------------------------------------
At 03:14 PM 5/25/01 -0400, you wrote:
murphy-rebel mailing list.
Drew and Jan
more engines
Bob It's only 2.5-6.5" longer than an 0-320 and it uses a bed style mount
so it should mount quite tight to the firewall. It's also 6" narrower so no
need for a prop extension and it's at least 25lbs.lighter. Plus 8 cyl.
smoooothness :-)
.......bobp
