Hi there,
I noticed there was a bit of talk here regarding inspection holes in the leading edge of the Rebel wing.
I have two in each wing, one in front of the front wing attach bracket and one in front of the strut attach bracket (one behind the strut as well). I placed doublers around all.
I have done over 300hrs in my Rebel now, through sometimes quite rough conditions, there is no sign of any form of cracking etc.
Any opinions on this, was I not supposed to do this??
Alister
Wing inspection holes
Hi Alister !
Sounds like you're OK, with the doublers, but a lot of the
wing strength is from the "D" tube, and it probably isn't a good idea
to put extra holes in it, for those who haven't yet.
My comments are general, as a caution to all ...
The root area is particularly important on the whole wing - I've
seen the steel girder test stands where the wings are mounted and
sandbagged to test when and where they fail. The Rebel wings will start
to crumple on the top, in the first bay out from the root, so that
is an area to absolutely avoid adding extra holes. Fortunately,
there's nothing there to give a reason for holes, so nobody has
had problems. The other high-load area is near the strut attach,
as that is the pivot point for the loads. Check with the factory
for hole sizes and positions, and use doublers.
This explains my unease when I hear comments about builders
skipping rivets on the leading edge skin in front of the tanks -
that is a VERY important area of the wing ! Do everything you can
to ensure that the leading edges are rivetted as close to spec as
possible.
Of course, the failures in testing occur well beyond anything
you should ever experience in normal flight, so there's no need
to panic. It's just a good idea to do as much as you can to prevent
possible future problems ...
The beauty of the Rebel design is that almost all failures
would be progessive and gradual, so you'd still have a good chance of
being able to fly it home for repairs. (Albeit perhaps with a
bit of extra dihedral ! ;-) )
....bobp
---------------------------------orig.--------------------------------------
possible.
....bobp
holes in the leading edge of the Rebel wing.Hi there,
one in front of the strut attach bracket (one behind the strut as well). II have two in each wing, one in front of the front wing attach bracket and
conditions, there is no sign of any form of cracking etc.I have done over 300hrs in my Rebel now, through sometimes quite rough
bsp; Any opinions on this, was I not supposed to do this??
Alister
<HTML><HEAD>
<META content="text/html; charset=iso-8859-1" http-equiv=Content-Type>
<META content="MSHTML 5.00.2614.3500" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT face=Arial size=2>Hi there, </FONT></DIV>
size=2> &n
leadingI noticed there was a bit of talk here regarding inspection holes in the
front ofedge of the Rebel wing.</FONT></DIV>
<DIV><FONT face=Arial size=2></FONT> </DIV>
<DIV><FONT face=Arial size=2>I have two in each wing, one in
(onethe front wing attach bracket and one in front of the strut attach bracket
behind the strut as well). I placed doublers around all.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial size=2>I have done over 300hrs in my Rebel now,
cracking etc.</FONT></DIV>
<DIV><FONT face=Arial size=2>Any opinions on this, was I not supposed to do
this??</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial size=2>Cheers</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial size=2>Alister</FONT> </DIV></BODY></HTML>
