Wing Leading Edge Question
David Ricker
Post by David Ricker » Fri Feb 17, 2012 8:56 pm
Hi Folks
We have been working on the wing structure and have a question about the leading
edge spar and how it affects installation of the leading edge skin. Our kit is
an Elite but this should apply to any high gross Rebel and probably any Rebel
except the SR. I believe the wing structure at the leading edge is the same.
Looking at the leading edge ribs and front spar, it looks like when the skin is
installed it will need to pull the flanges of the front spar out to meet the
skin (as if the spar was not wide enough). I say this because when I wrap a
strip of sheet metal formed to the shape of the skin around the ribs it clears
the spar flanges by a significant amount. It looks like the spar would have to
be pulled out to match the profile of the skin. Is this normal? Does the thick
high gross skin pull the spar out to match it and not leave funny dimples when
the skin is riveted in place?
As a check of my method, what is the distance (in the horizontal plane) from the
front face of the spar to the most forward point of the leading edge skin on the
inside of the skin (the inside face of the skin fartherst from the spar)? I get
15/16" (.937").
As a follow on question, if the ribs and the front spar are not perfectly
aligned (spar to rib, vertically) does the skin pull the spar in place nicely
and not affect the profile of the leading edge skin?
Dave R.
Elite 583
David A. Ricker P. Eng.
DARTEC Engineering Inc.
Fall River, Nova Scotia
Canada, B2T 1E8
klehman
Post by klehman » Fri Feb 17, 2012 8:56 pm
Hi David
My leading edge extends approx. 0.95" forward of the fwd spar about like
yours and fits just fine. It also fit fine prior to riveting as long as
there was a cleco in most every hole.
If the rib protrudes farther than the leading edge spar (vertically) it
will leave a bump in the leading edge at each rib after riveting so you
may wish to correct this if you can. It doesn't seem to matter much if
the spar flange is a little higher than the rib though. I was very picky
about bending the flanges of the ribs to match the leading edge as best
I could but I did not bend the forward spar flanges at all.
David Ricker wrote:
Hi Folks
15/16" (.937").
David Ricker
Thanks Ken
The bumps are exactly what I am concerned about or vice versa dips along the front
spar line where the skin would be trying to pull it up in place since the front spar
doesn't seem wide enough (vertically). I am concerned that it would be necessary to
re-shape the ribs to meet the spar, it would seem to me that they should be right
straight from the factory.
Has any one else come across this issue and how did you deal with it or is it a
problem at all? Wayne, is this something you have seen in the bunch of wings you have
built?
Dave R.
klehman@albedo.net wrote:
Hi David
David Ricker wrote:
Hi Folks
15/16" (.937").
murphy-rebel mailing list.
Canada
Post by Wayne G. O'Shea » Fri Feb 17, 2012 8:56 pm
To: "David Ricker" <ricker@dbis.ns.ca>
Sent: Monday, May 07, 2001 10:31 PM
Subject: Re: Wing Leading Edge Question
Dave, the first thing of course is to make sure the rib is fitted properly
to the front spar. It only takes a little bit of misplacement to get that
hump in the skin (of course if they are already drilled/riveted/etc, you
will have to work with what you have). It is not so much the rib flange
being centered (due to different "approach" angles from rib to spar, top
bottom), as it is smooth flow to the front spar from the rib flanges. I
like
to use 2 spring clamps on each rib to align the front spar. I clip them
sideways to hold the rib flange and spar flange together for a smooth
transition top and bottom. I have found on a few wings that it was
necessary
to "caress" the forward "point" (the front corner on the bend line from
rib
face to rib flange) of the leading edge rib flanges down. I use a small
bucking bar and a small ball peen hammer to just roll the point down a bit
to smooth the transition. IF you are seeing a small stress point at each
rib
flange when you push the leading edge down over the spar, you need to peen
these points down a bit, as when riveted they only get worse! Look at most
flying Rebels and you will see these "proud points" at most of the top
leading edge rib flanges forward most location (even mine, but we learn as
we go!). Shouldn't be as much of a problem for you with the .032 leading
edge skin, as compared to the Rebel's .020 skin, although I did have to
round off (peen) a few flanges on the SR2500 wings I did to get a nice
fit!
If that doesn't work then your front spar was bent to narrow between
flanges!
Regards,
Sent: Monday, May 07, 2001 9:53 PM
@albedo.net>
Sender: <murphy-rebel@dcsol.com>
Errors-To: <mike.davis@dcsol.com>
Thanks Ken
the front
front spar
necessary to
be right
is
it a
wings you have
built?
Dave R.
Hi David
like
as
it
you
picky
best
David Ricker wrote:
the leading
Our kit is
any Rebel
the same.
the skin is
meet the
wrap a
it clears
would have to
Does
the thick
dimples when
plane) from the
skin on the
spar)? I get
perfectly
place
nicely
Canada
bransom
Post by bransom » Sat Feb 18, 2012 2:53 pm
Hi all,
This was touched on at least once before that I've found in the archives.
I got the slight "proud" bumps at the front of the LE ribs where they end
before the front spar, on top. I had looked for this possibility before riveting
the LE on, and tapped over a few rib flanges, but now that it is done, I can
see some bumps even so. I don't spose there is anything that can be done
(within reason) now that the LE is riveted on?
-Ben /496R
Post by Ken » Sat Feb 18, 2012 2:53 pm
I thought I had reformed the flanges enough to take care of that too but
nevertheless some minor bumps showed up.
I suppose it could be an excuse to add Angus's drooped leading edge STOL
kit ;)
bransom@dcsol.com wrote:
Hi all,
-Ben /496R
bransom
Ah well, yeah, mine aren't too bad either. Just seeing them as I walked by
for a couple weeks I thought I'd ask if there was any magic to make them go
away. Yes, Angus' cuffs occurred to me too. :) I even thought about
tapping one with a hammer, but I think it would take more than a tap and
lead to bad news. Time to proseal a tank I guess.
-Ben
kit ;)
Hi all,
riveting
can
done
-Ben /496R
