trim tab hinge pin
Jason Beall
trim tab hinge pin
Post by Jason Beall » Fri Feb 17, 2012 8:55 pm
Hi all,
Should I bend the end of the hinge pin for the trim
tab? The instructions only say to cut the pin 3/4"
longer than the hinge...it doesn't mention bending the
end. What's the 'best practice' with this?
-Jason
Jason Beall
Super Rebel No. 131
Aberdeen, Scotland, UK
super_rebel131@yahoo.com
Do You Yahoo!?
Yahoo! Auctions - buy the things you want at great prices
http://auctions.yahoo.com/
bob.patterson
trim tab hinge pin
Post by bob.patterson » Fri Feb 17, 2012 8:55 pm
Received: from bretweir.total.net ([154.11.89.176])
by dcsol.com (wcSMTP v5.4.449.4)
with SMTP id 68996671; Sun, 29 Apr 2001 05:46:32 -0800
Received: (qmail 13255 invoked from network); 29 Apr 2001 13:46:29 -0000
Received: from unknown (HELO ip27.toronto77.dialup.canada.psi.net) (154.20.71.27)
by bretweir.total.net with SMTP; 29 Apr 2001 13:46:29 -0000
Mime-Version: 1.0
Subject: Re: trim tab hinge pin
Hi Jason !
You can bend one end before inserting the pin, as it's easier
when you can clamp it. Then bend the other end after inserting.
Some folks hammer the one end to enlarge it, like a solid
rivet, but I think that might make it a lot harder to remove sometime
later, when you needed to replace or service it.
-------------------------------orig.------------------------------------
At 02:26 AM 4/29/01 -0700, you wrote:
Hi all,
-Jason
Jason Beall
Super Rebel No. 131
Do You Yahoo!?
murphy-rebel mailing list.
Jason Beall
trim tab hinge pin
Thanks Bob!
-0800
2001 13:46:29 -0000
13:46:29 -0000
Mime-Version: 1.0
Hi Jason !
pin, as it's easier
after inserting.
like a solid
to remove sometime
Hi all,
-Jason
Jason Beall
Super Rebel No. 131
Do You Yahoo!?
prices
subscribed to the
the message.
subscribed to the
message.
Jason Beall
Super Rebel No. 131
Do You Yahoo!?
trim tab hinge pin
Post by Wayne G. O'Shea » Fri Feb 17, 2012 8:55 pm
Jason, another "angle" on the trim hinge is to just make it (the pin) the
length of the hinge and drill a small hole through the last hinge loop and
the pin, to insert a small length of .040 safety wire through. Or put a bend
in the end closest to the rudder (to use as a handle) so you can pull it out
after everything's assembled, and drill the hole in the other end for the
safety wire to hold the pin in place. This will allow for easy disassembly
if the need ever arises. If you bend both ends, chances are you aren't going
to ever get the pin back out, if you had to!
Regards,
Sent: Sunday, April 29, 2001 4:43 PM
Thanks Bob!
-0800
2001 13:46:29 -0000
13:46:29 -0000
Mime-Version: 1.0
Hi Jason !
pin, as it's easier
after inserting.
like a solid
to remove sometime
Hi all,
-Jason
Jason Beall
Super Rebel No. 131
Do You Yahoo!?
prices
subscribed to the
the message.
subscribed to the
message.
Jason Beall
Super Rebel No. 131
Do You Yahoo!?
Roland Kriening
Trim Tab Hinge Pin
Post by Roland Kriening » Sun Feb 19, 2012 11:36 pm
What is the easiest and cleanest way to secure the trim tab hinge pin? I
need to do the door hinges as well.
Roland
