What Zinc Chromate Epoxy Primer alternatives would you recommend? I haven't been able to track down any Zinc Chromate Epoxy Primer down under. I've found a few self etch primers that are supposed to be good for aluminum but are these appropriate? What do you suggest?
Philip
Zinc Chromate Alternatives
Re: Zinc Chromate Alternatives
Not sure if it can be had in Oz but we use Dupont Corlar self etching primer available from autobody material jobbers. I called the Dupont tech line & asked and this was their recommendation.TongueTied wrote:What Zinc Chromate Epoxy Primer alternatives would you recommend? I haven't been able to track down any Zinc Chromate Epoxy Primer down under. I've found a few self etch primers that are supposed to be good for aluminum but are these appropriate? What do you suggest?
Philip
Elite583
G'day Dave, Phil and others .....
Ok - I used aerosol cans of Zinc Oxide - rather than Zinc Chromate
( Zinc Oxide is no where near as dangerous / carcenogenic as the chromate - so I have been told )
Zinc Oxide is available from many outlets in Oz .... "A.P.E." at Bankstown Airport carries it
Aircraft Spruce carries it etc ...
I only used it between overlapping skins - mainly to protect against
Any water electrolysis that may occur ....
Don't forget - the Rebel is made with 6061T6 - which is "exterior grade" ( and "structural grade" as well ) - aluminium !
IE : it's NOT like 2024T3 - which HAS to be treated with something ALL OVER - due to its crappy
Corrosion properties !
Unless you are puting your Rebel on floats & SALT water - you don't need "all over protection" !!!
Hope this helps !
Rick in Orstraylya ....
D'oH !
Hope this helps !
D'oH !
Rick "Biggus" Harper in OZ
Kits 541 & 432
Kits 541 & 432
G'Day Dave, I am using BMS 10/11, a Boeing spec epoxy primer between all the faying surfaces and assembling while wet, including dipping the rivets.
Just hope hope that I never have to take anything apart. It is available from PPG in Tullamarine, or if you have a friendly airline LAME, a bit cheaper.
(they are fussy about shelf life.) PS just don't get it where you may want to paint later.
John
Rebel 804 down under.
John
Thanks everyone. I took the plunge and bought some EP420/430 from Aviaquip. I'll use that between mating surfaces at least. Being near the coast, I will probably do a light dusting of self etch primer on the inside surfaces.
Philip
Philip
Rebel 489R
