easy the rest of the trip.. My parents live in Duncan(1/2 way between the Nanaimo and
Victoria airports).. I've made the crossing MANY times.. I'll admit it's been a couple
months since I've been.. But there are several ways to get across the pond..
South of Vancouver Interational there are two VFR routes to the Island.. Point Roberts
or White Rock to East Point, then on to your destination...
1. Call up Vancouver Terminal once you are in the air and near either Pt. Roberts or
White Rock, and take your chances... I've never been denied access yet, but I have heard
of people who have been.. I think it has a lot to do with how "professional" your
initial callup is.. If they see that you are where you say you are, know where you're
going, etc.. They will let you in.. Depending on how busy the controllers are, you can
request an alternate route direct to your destination, I've only had to fly all the way
to East point once.
2. When you file a flight plan with FSS they will give you a transponder code. If you
don't file a flight plan you can call 1-800-YVR-CODE, tell them your point of departure,
requested routing, and destination, they will give you a transponder code.
3. The easiest way to go.. Fly around to the North of Vancouver.. Fly through the
Vancouver Harbour at 2000', the controllers there are very helpful if you want to circle
the downtown core for photos. Continue out over Bowen Island, you can begin a climb
here, not above 3200.. Once past Gower Point continue climbing to 4500 for the
crossing.. About the time you get over the Sechelt airport you can make your turn out
over the water and cross.. Watch the restricted area, FSS can tell you if it's active.
With a little planning you CAN fly to/from the Island without having to contact any
towers, avoiding the Class 'C' airspace, and keeping some semblence of gliding distance
to land.
If you don't mind following a set route, and talking with the Terminal Controllers, the
trip from Chilliwack-Vanc.Harbour-Nanaimo-Victoria-White Rock-Chilliwack is a spectacular
one!!
Bob Patterson wrote:
*-----------------------------------------------------------------------------------*Hi Ramblers !!
The map package is in !! If you haven't ordered yet, you
can still get it, priority post, in a couple of days - now that all
the maps are current. Call VIP Pilot Supplies, at 1-800-361-1696 and
ask for the Rebel Ramble 2000 Kit, item number K031, for $192.87 CDN.
Mine came on Friday - had a look at the new TRSA's around
Calgary & Regina - it's getting ugly !!! Going to be a bit of a pain,
but it still <is> possible to fly all the way without a transponder.
Those of you who were thinking about flying out to Vancouver
Island - check out that VTA !! Now you know why I'm NOT keen on THAT
trip !! Crossing all that water at 1,500 ft. - even WITH transponders -
NO THANKS !!! I think taking the ferry ride looks pretty promissing !! :-)
It's interesting reading - think I've found at least one more
place where we can cross the border WITHOUT filing a flight plan !!
We'll certainly have LOTS of choices of places to stop, from Winkler
on...
....bobp
The Rebel Ramble List is for the discussion between
individuals interested in participating in, or
gaining more information about the Rebel Ramble
flying adventure. Archives located at:
